What equipment is needed for the Panasonic TH-50PHD7UY?
Discussion in 'Panasonic TVs Forum' started by freddyboy3333, Feb 7, 2005.
  1. freddyboy3333
    freddyboy3333
    First I need to inform you about that I am a total newbie when dealing with Home Theater so please explane to me everything as accurate as possible.
    Im going to buy the Panasonic TH-50PHD7UY. I'd also like to order all the equipments at the same time. Therefor I need your advice for what equipment I need. Im going to get my self a sorroundsound system 5.1/6.1/7.1 at a price range of 600-1000 dollars.
    1I want a dvd player that reads dvd-r, dvd-rw etc and records on a HD 120GB+ no dvd recorder. Any top dvd players you have information about? 100-600 dollars range.
    Of course I need a tuner also. 2What do you find is the best fit for my Panasonic TH-50PHD7UY? price range 0-300 dollars
    3what is dvi :blush: ,what is it for, do I need it?
    4what is HDCP :blush: ,what is it for, do I need it?
    5what is RCA :blush: ,what is it for, do I need it?
    6what is HD-SDI :blush: ,what is it for, do I need it?
    7what is HDMI :blush: ,what is it for, do I need it?
    9What cards/terminal do I need for my TH-50PHD7UY if I want the above? note that I want to be able to connect my computer to the TH-50PHD7UY
    10Any other accessories you think I want/need, please tell me!
    Anyone that can answer these 10 questions I would really appreciate it!! :)
    But even if you can only answer one, please do so :)
    /Olle
