What else would I need to spend if I buy this (PW7) deal?
Discussion in 'Plasma TVs Forum' started by Stampax, Jul 8, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,405
    Northampton
    +88
    Thinking seriously of getting this:
    http://www.flatdeal.com/TH42PW7.htm
    seems a good price AND a 3 year warranty.
    Now I know i'd need a wall backe, but what else - it says it comes with a free scart board, will this do?
    I dont need a tuner, as I have sky plus, and alreayd have an amp and 5.1 set up.
    Need to connect the usual stuff- xbox, sky, pc, dvd player, amp, etc
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    well you have 1 scart and 1 vga to start with.......does your amp have scart in and out?.......are you looking for best or most cost effective way of hooking everything up?
  3. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    I suppose it all depends what video in/outputs your amp has. If it has component then the deal at AV-Sales here includes the Wall Bracket but you then have the choice of boards
  4. Dave
    Dave
    Jul 3, 2005
    11,497
    163
    +3,401
    Go to 24-7 electricals website and take a look. Same deal for £1140.
  5. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    I went for the component board instead of the scart, and got a JS Tech RGB to VGA convertor.
    All my scart connections are "daisy chained" and go through the JS convertor (and on to the VGA input) ... and my DVD player (which has component out) hooks directly to the component connections.
    As mentioned above - it all depends what connections your kit has ...
    Dez
