What editing software
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Stuteman, Jun 9, 2004.
  1. Stuteman
    Stuteman
    Dec 10, 2003
    73
    Can anyone recommend editing software. Nothing fancy required. Just a bit of cleaning up, titles and perhaps some commentary.
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    If you're running Windows XP, then Movie Maker is probably good enough for what you need - make sure you upgrade to version 2.0 (free download from Microsoft) as it's a far better product than version 1 that ships with XP.
    If, after using it, you feel you need something more advanced then you can start looking at the likes of Pinnacle Studio, ULead Video Studio, which cost a few tens of pounds or so, right up to products such as Vegas, Pinnacle Edition and Adobe Premier which cost hundreds of pounds.
  3. Brian110507
    Brian110507
    If you go to www.papajohn.org you can learn a lot more about MovieMaker 2 and what you can do with it.
