what dvdrw?
Discussion in 'Blu-ray & DVD Players & Recorders' started by stevomacca, Jun 11, 2005.
  1. stevomacca
    stevomacca
    Jan 27, 2005
    267
    i'm after a dvdrw that'll do the -r variety, multi-region, and has a 100gb hdd.
    which one will i buy for around £300?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    Have a look at the 'Which DVD Recorder?' link in my signature for basic DVD recorder buying advice. The popular models that fall within the specs of what you want are:
    - Panasonic EH50 (80GB HDD)
    - Toshiba RDXS34 (160GB HDD)
    - Sony RDR510 (80GB HDD)
    - Pioneer 720 (160GB HDD)
    All have pros and cons - do a search of the forum for advice/further info on each.
  3. stevomacca
    stevomacca
    Jan 27, 2005
    267
    thanks, i think the toshiba might be the right one for me cos the tv i'm buying is also a toshiba.
    any advice on that?
  4. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    That is not a good premise for buying a Toshiba recorder. Did you do a search like Rasczak suggested?
    Any further advice will depend on what you want to do with the recorder, and giving details of the TV. Some advice would probably be better given from the 'Video Components' section of the forum.
