what dvd to go with panasonic pv 500
Discussion in 'Panasonic TVs Forum' started by daveblade, May 27, 2005.
  1. daveblade
    daveblade
    Apr 2, 2005
    364
    +13
    iv been checking prices and reviews on the pv 500 and when i do move house i want a good dvd player to go with the tv
    iv been tempted by the deal at richer sounds for 600 pounds for the dmre 500 but would also consider the pioneer dvr920
    i was so sure that i would get the pani dvd but now i dont know again
    any help please esp h dragons help if poss
    thanks :lease:
  2. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    personaly i would just get a fairly cheap dvd with component out put and wait for high def dvd players with hdmi output.
    but thats just me and opinions may differ.
  3. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    If its just a player you're after, then why not go for the Panasonic DVD-S97?
    You can pick these up for about £200 now (I paid £250 just a couple of months ago!).
    Its a top-notch player and an ideal partner for the PV500 range as it has HDMI connectivity.
    I've currently got mine connected up via RGB SCART to an old JVC CRT at present, but the PQ from it has been absolutely outstanding.
    I'm just waiting for my plasma to turn up so I can see what this can do over HDMI!
    :thumbsup:
  4. daveblade
    daveblade
    Apr 2, 2005
    364
    +13
    thanks ill have a think about it
  5. theo cupier
    theo cupier
    Sep 18, 2004
    1,660
    63
    Amersham, Bucks
    +113
    I've got an SD220E DVD player at the moment, which has component out, but not progressive.
    As/when I get myself a panel like the PV500 will the SD220E serve me well enough for now to make it worth waiting for Blu-ray DVD players in the (not too distant) future?
    Or is it worth while upgrading the DVD player immediately to something with prog scan & HDMI? Alternatively, would I gain much in getting the panel in a package deal which includes a DMR-ES10 - in terms of improved PQ from the DVD?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ERm dont you get a DMR-Es10 free with the PV500? some dealers will let you upgrade to the ES50 with HDD
  7. theo cupier
    theo cupier
    Sep 18, 2004
    1,660
    63
    Amersham, Bucks
    +113
    HD - according to this thread, there are a few retailers bundling that DVD with the PV500:
    http://www.avforums.com/forums/showthread.php?t=213071
    Have I read it wrong?
    Anyway, what thoughts on the SD220E? Does it need upgrading immediately or will it do itself/the screen justice until Blu-Ray time?
  8. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,091
    notts.
    +64
    I did ask about upgrading to the es50 but was told it had to have a hardware mod to make it multi- region that was from the bloke at pansonic the es10 can be made multi region by remote hack.
    Cheers Gonzo.
  9. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Dave,
    I have the E500 and it's a great machine, I'm still extremely pleased with mine after a month or so's ownership and I got mine for a bargain from Richer Sounds, the £599 promotion.
    But, and it's a big but... If you have the the PV500 I think you maybe better off with the Pioneer DVR920 as I believe it has HDMI output and good as the Panny is, it doesn't.
    I think either make a great choice for a DVD/HDD recorder to compliment your plasma.
    S.
