What DVD Recorder do i Need?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Trekker, Feb 13, 2005.
  1. Trekker
    Trekker
    Feb 13, 2005
    69
    HI there.
    I was wanting to get my mum a DVD recorder to replace the VHS Recorder that she has.
    I want to know what type of recorder would be best, below are the things that i need:
    To record and play on a daily basis over and over on the same disk.
    Price range of about £100 - £200
    This is to record a lot of things from the TV.
    Was thinking of one that will use RAM disks as they are able to record over and over.
    Any Help would be appreciated.
    Trekker
  2. DVD-RAM
    DVD-RAM
    Buy a Panasonic E55, which uses DVD-RAM. You can find them from between £170-£200.
    They are the dogs biscuits!!!! :)
    Whatever you do, do not even think of buying anything with 'Philips' written on it.
  3. Rob20
    Rob20
    Jul 3, 2004
    3,282
    +779
    If you're not bothered about archiving or playing discs on other dvd players, but just want to be able to time shift programmes, I would agree with a RAM player like the one suggested above. RAM discs are apparantly the most stable, reliable discs on the market, and can be re-recorded onto some 100,000 times, (other rw discs are 1,000 I believe). 10 RAM discs can be bought for £15 + p&p from SVP. Very reliable as I've used them myself. Click the link below:
    http://www.blankdiscshop.co.uk/acatalog/FOR_DVD_RAM___CLICK_HERE.html
  4. wokeye
    wokeye
    Apr 15, 2003
    805
    +99
    I was also thinking about one of the Panasonic recorders too. I know this player uses DVD-Ram discs and it also states that it uses DVD-R discs. Can they use DVD-RW discs or is this not the case. Thanks
  5. jesmat2003
    jesmat2003
    Mar 8, 2004
    74
    Panasonic recorders cannot record on to DVD-RW discs. However, DVD-RAM is arguably better for recording on, unless you wish to play the recordings on another player afterwards, in which case DVD-RWs offer better compatibility.
  6. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Although I'd suggest going for caddied rams as you don;t have to worry too much where you stick your fingers and you can almost pretend they're a video tape...
  7. jpurkey
    jpurkey
    I agree. DVD-RAMs while probably more durable, can be a bit write-fussy when it comes to dirt and dust. The double-sided cartridges are probably better. You do have to flip them to use the other side, but you get twice the capicity in the same amount of space.
