What DVD Recorder? - £200 to spend
Discussion in 'Blu-ray & DVD Players & Recorders' started by Winnie, Nov 4, 2004.
  1. Winnie
    Winnie
    Mar 12, 2001
    219
    Enfield
    +4
    Well, took my Mico Espejo R311 back this week and got a £200 refund. Had this since Xmas but recently it would freeze after about 5-10 seconds of starting a recording. Only way to unfreeze it would be to physically unplug it. It would also take ages to READ a disc, before coming back with "No disc", even though the disc was new and had just been recorded onto by that recorder :(
    Also found the clock on the machine would run fast (about 15mins over 3 months).
    Anyway I now have up to £200 to find a replacement, anyone offer any advice. Just want something reliable and proven, without any fancy gimmicks that I won't use.
    Only one I have in mind at mo. is the Panasonic E55 - Yes/No ?
    Paul
  2. dude1971
    dude1971
    Yes.
    Regards
    The Dude
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    I have the E55 and am really impressed with it. The flexible record is very useful. The only thing to worry about is the re-writable format of DVD-RAM, this is only a problem if you want to play re-writables in another player otherwise its the best format.
  4. buckaroo
    buckaroo
    Sep 13, 2004
    128
    The Panasonic DMRE55 is a top seller. And I can see why, as I've had one for about two months. It's your best bet. Get a multiregion one from here [​IMG] and your well awaaay! :smashin:
    Avoid the Phillips models at all costs. :mad:
  5. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    is pan e55 better than pioneer 220?
  6. Winnie
    Winnie
    Mar 12, 2001
    219
    Enfield
    +4
    Question : Is the MR mod a handset hack, firmware or a chip ?
  7. dude1971
    dude1971
    I had to get Richer Sounds to send mine away to be mod'd so it can't be a handset hack. My money is on a cd hack.
    As for DVD Ram being unwatchable in other machines, my Panasonic player can watch them (uncaddied of course).
    Regards
    The Dude
  8. Rasczak
    Rasczak
    Apr 3, 2002
    22,082
    Warwick
    +2,935
    All things being equal yes - the Panasonic has more output options, better DVD playback and DVD-Audio support. The Pioneer 220 is well worth considering if you need DVD-RW support, i.e. you want to play your re-writable recordings in (e.g.) an upstairs DVD player. However if you use this feature then you loose many of the benefits of a DVD recorder (Timeslip, Chasing Playback, Playlists etc) so you might as well use DVD-RAM.
  9. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    I've bought the Pioneer 220S and have found it thus far to be a very decent budget DVD recorder with all of the features that i need........... so i would highly recommend it
  10. K-BOXER2
    K-BOXER2
    hi there just ordered the above machine today myself good price at comets if bought online :thumbsup:
