What dvd re-writer do you recomend?
Discussion in 'Desktop & Laptop Computers Forum' started by tony kop77, Jul 19, 2004.
  1. tony kop77
    tony kop77
    Sep 27, 2002
    6,200
    103
    Northamptonshire
    +284
    I will be buying a dvd re-writer this week but dont know much about them. I am not too fussed about backing up my films though my brother sometimes records his family when on holiday or someones birthday for example and he might want to put it on dvd rather than video tape at times.
    I mostly want a dvd re-writer to patch winning eleven 8 (Pro Evouloution 4) and I think I will go for either of these 2. which would you advise me to buy.
    Sony DRU-700A (Dual Writer +/-) - RTL Double Layer Drive £117
    2.4x DVD+R Double Layer
    8x DVD+R / 4x DVD+RW
    8x DVD-R / 4x DVD-RW
    12x DVD-ROM / 40x CD-ROM
    32x CD-R / 16x CD-RW
    Superfast Hi-Speed 8x DVD writer with support for DVD+R9 Double Layer recording.
    Latest generation DVD+/-RW DL drive that writes on DVD+R(W), DVD-R(W), DVD+R9 & CD-R(W).
    The ideal device to create and play movies, music, photos and data.
    Copy existing DVDs and CDs or compile your own Data-, Audio-, Video
    DVDs and -CDs.
    Stores up to 8,5 GB on a Double Layer DVD!
    Capture, trim and convert your video. Use ready-to-go-templates to
    edit and create titles, overlays, voice and audio. Burn, play and share
    the video on DVD or CD.
    DVD: 8x DVD+R, 8x DVD-R, 4x DVD+RW, 4x DVD-RW, 12x DVD-ROM
    DVD Double Layer: 2,4x
    CD: 32x CD-R, 16x CD-RW, 40x CD-ROM.
    Reads:DVD-ROMs,DVD-Videos, CD-Rs, CD-RWs, CD-ROMs, Mini CD and
    MP3 CDs.
    Free helpdesk, clear installation instructions included.
    Product specifications
    DVD+R Double Layer: 2,4x, DVD+R: 8x, DVD+RW: 4x, DVD-R: 8x, DVD-RW: 4x, DVD-ROM: 12x
    CD-R: 32x, CD-RW: 16x, CD-ROM: 40x
    Tray type
    Electrical load / eject, with emergency eject
    Reading modes
    DVD-R, DVD+R, DVD-RW, DVD+RW, DVD-Video, DVD-ROM, Digital-Audio (Red book) and CD extra,
    CD-ROM (Mode 1 -Yellow book), CD-ROM XA & CD-I (Mode 2/Form 1-Green book), CD-Bridge &
    Photo-CD (single and multi-session), CD-Video
    Supported media
    DVD+RW, DVD+R,DVD-RW, DVD-R, DVD+R9, CD-R, CD-RW, High Speed CD-RW, Mini-CD (8 cm).
    (Can not record DVD-RAM media)
    Writing modes:
    DVD RW: Random Access Write, Sequential Write
    DVD R: Sequential Write
    CD-R/CD-RW: Disc At Once, Session At once, Track At Once, Multi-Session, PacketWrite
    Writing formats
    DVD R/DVD RW: DVD-ROM, DVD-Video, DVD-R9 (Double layer)
    CD: CD-DA, CD-ROM, CD-ROM XA, CD Extra, MP3 CDs, Mixed-ModeCD,VideoCD, PhotoCD, CD
    TEXT, Bootable CD
    Performance
    Access time DVD 140 msec. - CD 120 msec.
    Interface
    IDE/Atapi
    MTBF
    50.000 hours
    Safety standards
    Application Standard UL1950 CSA950 EN60950 HHS Class1 EN60825-1 Class1
    Radio Interference EN55022 EN61000-3-2 EN61000-3-3 ENN50082-1
    Physical specifications
    Height 4,2 cm x Width 14,7 cm x Length 20 cm - Weight 1100 gr
    Environmental Specifications :
    Temperature:
    Operating +5° to +45° C
    Storage -30° to +60° C
    Gradient 11 °C /hour (Max.)
    Humidity:
    Operating 10 - 90 % (No Condensation)
    Gradient 10 %/hour (Max.)
    or
    NEC ND-2500A 8x DVDRW Dual Writer
    Specification
    Read speed:12x Max DVD-ROM and 40x Max CD-ROM
    Write Speeds:
    DVD+R: 8x Max
    DVD-R: 8x Max
    CD-R: 32x Max
    DVD+RW: 4x
    DVD-RW: 4x
    CD-RW: 16x
    Mechanism: motorized tray load mechanism for horizontal and vertical use
    Interface: IDE / ATAPI
    Burst transfer rate: PIO mode 4 / ultra DMA 33
    Cache memory: 2 MByte
    Audio: Head phone jack and volume control at front plus digital-out and line-out at the back (MPC compatible)
    Media/Modes supported: DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-Video, CD-ROM, CD-ROM XA, CD-Audio, CD Extra, CD Text, CD-I Ready, CD-Bridge, Photo-CD, Video CD, Hybrid CD
    Writing methods: DAO (disc at once), SAO (session at once), TAO (track at once) with zero gap, variable or fixed packet, multi-session
    Compatibility: MPC Level 3, multi-read, PC2001
    Weight: 1,02kg
    Dimensions: 148mm x 42mm x 190mm
  2. Garrett
    Garrett
    Apr 21, 2001
    42,839
    2
    167
    The best thief you'll never see.
    +8,020
    I have the 106 version of this and have not one bad recording yet. See here.
  3. tony kop77
    tony kop77
    Sep 27, 2002
    6,200
    103
    Northamptonshire
    +284
    I have ordered the NEC ND2510A dual layer for £60
  4. BBD
    BBD
    Mar 13, 2001
    442
    Lutterworth
    +3
    I wouldn't bother with the Sony DRU-700A it's just a very expensive LiteOn 832s clone.
    I also bought the NEC 2510a. I'm pleased with it and it's good value for money. Have a look at www.cdfreaks.com forums for advice/confusion!
