what dvd player should i get?
Discussion in 'Blu-ray & DVD Players & Recorders' started by triplea4uk, Feb 7, 2002.
  1. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,011
    48
    Northants
    +85
    i have got £170 for a dvd player what one should i get. I want it be able to run all regions and support dts.
  2. Jase
    Jase
    Mar 16, 2001
    10,721
    United Kingdom
    +2,487
  3. alextgreen
    alextgreen
    Apr 17, 2001
    552
    London
    +5
    I'm happy with my Wharfedale DVD750S - does DD and DTS, is multi region, comes with all the cable you need (including scart) and plays video CDs rather well. Doesn't sound too bad with audio CDs either. Build quality isn't the best, and it sure isn't pretty, but it does the job very well for the money.
    ps - no, it isn't as ugly as a Cyberhome.
  4. Markster
    Markster
    Only two players to consider in the cheaper
    sub £200 bracket imo.
    Toshiba210
    Pioneer444
    Avoid paying £150 or less for a player, pay the extra and get one of these players instead it is well worth it.
  5. damtom1
    damtom1
    Has got to be the Toshiba 210e....Multi reg. from Richer Sounds£199
  6. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Sevenoaks are doing them for £199 (modified for multi-region use)
    and including 2yr guarantee)
