What DVD player for my plasma?
Discussion in 'Blu-ray & DVD Players & Recorders' started by John Langton, Mar 6, 2005.
  1. John Langton
    John Langton
    I have a fujitsu P50XHA10US and I live in the UK. What would be the best dvd player for this plasma. I was looking at the denon 2910 but not sure if this has proggresive scan
    John
  2. deanym
    deanym
    May 29, 2004
    1,833
    +143
    It has progressive scan and its fantastic. its gives 98% of the performance of the HDMI input.
    I'd highly recommend it.
  3. John Langton
    John Langton
    Cheers Dean. Havent denon brought out players with a DVI output? and if so then will it be better to connect a dvd player via the dvi or will it be better to buy a component board for my plasma and buy a dvd player such as the 2910?
    John
  4. deanym
    deanym
    May 29, 2004
    1,833
    +143
    2910 has a dvi output as well. its then up to you whether you want to use dvi or component.
    Check the threads for connections for your fuji, these may have some inof on differences between dvi and component performance.
  5. Cwhelan
    Cwhelan
    Jan 29, 2005
    148
    Milton Keynes
    Budget permitting If your looking at Denon also look at the 3910 it's an excellent player. Very pleased with mine. :thumbsup:
  6. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Yup, if you got the cash the 3910 is fantastic esp if you're replacing a cd player as well.
    Arcam Dv79 is also another that would demand serious consideration in that price range.
  7. John Langton
    John Langton
    Went into 7oaks today to enquire about a new DVD layer for my plasma. I am pushed towards the 2910 not being able to afford the 3910 and the guy in the shop sang praises for it. using the HDMI output to my DVI output with a converter on the lead converting the HDMI to the DVI input on the back of my plasma.
    I have a question though. I believe the HDMI carries the audio aswell but if I dont have any speakers connected to my plasma and I run my audio seperatly what is the point in using the HDMI from the dvd player? why not just use the DVI output?
    Also where is the cheapest 2910s are going for and what should I expect to pay
    Thanks for all info
    John
  8. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Depends on the player obviously but DVI out is going to be RGB 4:4:4 where as on some players HDMI can be YUV 4:2:2 (which is what is native on the DVD disc therefore no coloursapce conversion) . Arcam HDMI can do YUV 4:2:2 , not sure about Denon though.
  9. Cwhelan
    Cwhelan
    Jan 29, 2005
    148
    Milton Keynes
    7oaks normally give a competitve price for shops anyway but you probably get a cheaper price from a web shop. I normally use www.pricerunner.co.uk to give good comparisons.
    bueaty of a shop u can take it back no hastle & speak to someone (in my experience anyway)
    What price did 7oaks quote?
    CW.
  10. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Bettercables do a hdmi-dvi cable therefore you can run various versions of the hdmi straight into your display. The audio just to your amp. not many use the hdmi for sound - very few amps have an hdmi connection. Only top end ones! £4000+
  11. John Langton
    John Langton
    7oaks quoted me £500 for region 2 and £520 for region free. He then said if I bought it today I could have a multi region for £500
    John
  12. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Good price - esp when you can take it straight back to shop if any problems arise without faffing with internet returns.
    I paid same from local dealer.
  13. John Langton
    John Langton
    Is it worth paying them the extra £20 to make it multi region when you can get the firmware from here?
    John
  14. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Tell your dealer just to do it for free!!
    Mine did. No multi region, no sale!! it takes them seconds to do it! If they don't find another local who will!
    John, where are you based?
  15. John Langton
    John Langton
    Im based at an RAF Base near inverness. RAF kinloss to be precise. Forres Morayshire
