What DVD player for CDR Playback
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, Feb 12, 2001.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    Born in Bristol but now in Newport, (for my sins)
    +717
    I have a Samsung 709 which I am sort of happy with.
    Trouble is, I bought it some years ago, just to get into DVD.. I never imagined that 2 years later, Home Cinema would be one of my main interests.
    My system is fairly impressive, but the hub of it all is a 'budget' DVD player.
    The icing on the cake, is that I have a fast PC, DV camcorder, Firewire interface and SVCD software and therefore have the ability to knock up VCD/SVCDs..
    Unfortuantly, my 709 doesn't support CDRs.
    So, I want a player which has the following features:-
    - Multi Region (Automatic)
    - Macrovision Disabled
    - PAL 50 (Although I think this is going to be unlikely)
    - CDR Support
    - 2 x SCART
    - Good trick play (i.e the ability to fast worward at very high speed (The Samsung does 2, 4, 8, 16 and 32x))
    Does anyone have any recommendations/advice for me?
    Jon
  2. tan1415
    tan1415
    depends on your budget.
    Marantz,Pioneers and phillips all are capable of playing CDr.
    The Sony 7700 is also CDr capable.
    I am interested in the 535 from pioneer.
    Only thing is with the new RCE protection i don't really trust the automatic modifiers.
    I prefer the manual or auto/manual modification
  3. adamhamilton
    adamhamilton
    CD audio quality from the 535 is OK, but if you then connect up a 'proper' CD player
    you will notice the difference!
  4. Stick
    Stick
    Yes indeed!, especially if your CD player is not also a Pioneer
