What DVD player for 435xde
Discussion in 'Plasma TVs' started by gpm02, Dec 29, 2004.
  1. gpm02
    gpm02
    just got 435 xde, what dvd player should i get. go into sevenoaks and of course they say £900 Denon 3910 bit out of price range for a dvd player.
    Any suggestions ? good component player or HDMI/DVI? player
  2. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    948
    Scotland
    +18
    Sevenoaks are merely advising on a player that will complement your Plasma, I believe it also upscales to 720P which your 435 will handle.
    I personally use an Arcam DV79 with HDMI, if I couldn't afford a decent DVD player for arguably the best commercial Plasma on the market I'd probably consider an SD340 or Pioneer 575 at £70 and £115 respectively.
  3. gpm02
    gpm02
    I am not looking to penny pinch that much but not really prepaered to spend £800-900
  4. nicklang
    nicklang
    Jul 6, 2004
    179
    Newport, South Wales
    What about a 2910?
    they have the same Farouda (spelling?) proc. chip and give a nice pic
    ~£500
  5. buzzby
    buzzby
    I dont know what kind of budget you are looking at but i have just bought a Toshiba SD-340E from amazon. Its region free and has progressive scan. It also plays DIVX and XVID movies that you download of the net or encode your self.
    I have not had a prob with this dvd player and for the price i think its a real bargin
  6. Lizzard
    Lizzard
    Seems like Denon is no good for Pioneer according to Joe.
  7. gpm02
    gpm02
    so why is denon no good fo pioneer.
    can any one confirmthat the pq froma 2910 ill match the 3910 as stated?
  8. dj_johnnyg
    dj_johnnyg
    Pio 575 with a decent set of component leads - That's what I use & it's spot on for my needs. (I have a 435XDE also)
