What does this error mean?
Discussion in 'Desktop & Laptop Computers Forum' started by Comer, Aug 13, 2003.
  1. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +85
    Since last night if I go onto the Net after about two minutes I get the error shown in the attached file. I’ve gotta be fast in posting this so if anyone knows what it means and what I can do about it, I’d grateful if u could let me know
    Conor
  2. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Yeh looks like the worm that is doing the rounds, it's not that harmful. It's very easy to remove and you can read all about it here.
  4. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
  5. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +85
    Thanks Guys
    That seems to have sorted me out. Where would we be without THE FORUM?:)
    Conor:smashin: :smashin: :smashin:
  6. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +85
    Well it seems that I was a little premature with my celebrations. I ran the program to remove the worm and it seemed to work perfectly but then last night when I went online the message above reappeared and the PC restarted. I couldn’t keep the PC going long enough to download the latest antivirus so I got it on my neighbours PC (P166 with 32K modem-it took an hour in all) and when I ran the antivirus it fount the infected file and deleted it. But the problem remains. I don’t mind reformatting my home PC as I backed up all my work last week but two of the PC’s at work have the problem and reformatting those would be a big deal
    To add to my tale of woe, my Sony HS10 started giving problems two nights ago at 300 hours.
    Oh yea, and my dog got hit by a car
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    What is the direct link to MS for the XP fix as I have to email it to my parents?
  8. HMHB
    HMHB
    Nov 11, 2001
    26,864
    Nottinghamshire
    +5,651
  9. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
  10. baldbird
    baldbird
    This wound me up a treat on Tuesday night, every time i got close to sorting it out my pc shut down.
    If that's happening and u fon't have enough time to download the windows updates,
    control panel - network connections - rightclick on your connection - advanced - and set full firewall.
    That'll stop the virus coming on so u can download the updates. Then turn the windows firewall off as it restricts almost anything you want to download
  11. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +85
    Thanks for the replies. I just went to download the patch but one was for Windows PX 32bit version and the other was for Windows PX 64bit. How do I know which one I need
    Probably a very stupid question
    Conor
  12. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    i assumed i was looking 32 bit.... so thats what i have!
    Actually i havent seen this on my net pc, but my totally isolated hcpc has suffered..... but every time it did was when i was tweaking..... one of the running services which i tried to stop seemed to cause this to happen....... dounbt that hepls you but you never know!
    Ad
  13. HMHB
    HMHB
    Nov 11, 2001
    26,864
    Nottinghamshire
    +5,651
    I would guess that 99.9% of people have the 32 bit version of Windows XP as the 64 bit version has been produced for 64 bit processors. So unless you have an Intel Itanium or an AMD Opteron then you will be 32 bit.
  14. Zone
    Zone
    Jun 24, 2001
    6,754
    Barnsley
    +2,459
    You'll have the 32bit version, the 64bit version is only available with XP pro
  15. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +85
    Thanks everybody
    At last, I think I'm sorted
    Conor
  16. sinbrad
    sinbrad
    For Baldbird and anyone else who cares to take his advice??
    The last thing you want to do is deactivate your firewall. The reason??? Quite simple, the virus (worm) that is causing your computer to reboot also allows remote users to control your computer and do things to it that you don't want them to ie change setup, format hard-drive etc etc etc. The only way to stop this is to enable firewall therefore not allowing them access to your computer. If you read into the description of this worm it does tell you this. Anyway I think that you will find that the firewall doesn't restrict your downloads all that much to worry about. I would rather worry about unwanted guests
  17. HMHB
    HMHB
    Nov 11, 2001
    26,864
    Nottinghamshire
    +5,651
    EDIT
    Post deleted due to me not reading the rest of the thread properly :blush:
  18. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
