What does the volume setting actually mean ?
Discussion in 'AV Receivers & Amplifiers' started by iwatkins, Dec 26, 2002.
  1. iwatkins
    iwatkins
    Hi All,
    I'm sure this applies to other amps as well, but I have a Sony STR-VA555ES amp and the volume goes from:
    - infinity dB
    up to
    -0 dB
    I.e. the first is zero volume up to the latter which is fecking loud.
    If I have the amp at -65dB does that relate in anyway at all to the actual amount of noise in the room or is it just some figure plucked out of thin air that indicates in some way how hard the amp is working ?
    Ian
  2. rowbos
    rowbos
    Jul 9, 2002
    290
    Minehead, UK
    +3
    Think mine goes from -70 to +15 - quiet to loud - its a Denon.
    From what I have seen all manufacturers have their own system for describing volume levels, with no consistancy.
  3. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
  4. iwatkins
    iwatkins
    Thanks micb3rd, that makes it clear.
    Ian
  5. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Like micb3rd said its in DB's with 0 being the reference level and supposed to be the Dolby reference level. Although they are set up in the factory they will all be different depending on the equipment etc used so you still need to calibrate the system yourself with an sound pressure meter.
