niceguy235uk
As title really!
And also what benefits does it provide over standard ISP connections?
Cheers!
Cheers!
Local Loop Unbundling - in short it allows other companies to install thier equipment at your local exchange.
Cheers!
So if i decide to change ISP would it be better to opt for an ISP that operates this way?
The only reason i ask is that i am fed up with painfully slow speeds, even with a supposedly 8mb connection.
I am only just getting 1mb d/l speeds at peak times even though my line is apprently able to support 3meg.
But you cannot assume that LLU = good, BT IPstream is poor. If only it was that easy.![]()
Well if that's 50 kilo bits per second, then yes that's very poor. Not much better than 56k dial up which typically had throughput speeds of 48 kilo bits per second.
Also the ISP's you have chosen dont exactly have good track records. Virgin are heavily congested & Tiscali will throttle you at the drop of a hat, if you d/l a service pack etc (let alone use p2p).
Check out their ratings here for example> http://www.dslzoneuk.net/isp_ratings.php
However bad ISP or not, really need to see those line stats to see what's going on.
Out of curiosity, what are good/bad values for SNR and attenuation? I'm on a red exchange and my ISP is virgin (and getting awful up and downloading speeds) and I currently have a downstream attenuation of 18db and a noise margin of 13db
Shaz
guessing its my ISP
