David-Sheekey said:Not 100% sure.
I have had mine calibrated and then set both the normal mode then the cinema mode with DVE. The normal mode seems a bit more coourfull and slightly sharper, but there is more noticable soloraisation. Cinema mode seems ever so slightly washed out if you are not used to it, but it holds the black level better and has reduced solarazation.
