Member 354643
According to Wiki, it is "possible to support...audio data by incorporating the audio in the TMDS signal. Because DVI displays typically have no sound capabilities, a DVI to HDMI adapter/cable can then be used to connect the device to an HDMI display"
I'm sure there are a fair few DM800 owners who can confirm this is the case when used with the adaptor.
What I want to know is this...
Specifically what makes the Dreambox 800 HD better than say a Technomate 6900 HD? Is it actually possible of receiving more channels? Perhaps, to rephrase, what are the limitations of a Technomate over the Dreambox? If the answer is (as I likely expect) about being able to utilise 'special features' then could someone PM me because my googling skills have proved pretty fruitless so far!
If someone can convince me of the benefits then I may well be in the market for a Dreambox 800 HD soon. 1 Install, you're not far from me! Perhaps I'll call upon your services for a West London install?
not a problem i can help you out im actually just about to go to ealing now, if anyone else requires any help on this kind of thing check out my areas covered page areas covered | 1install this will tell you how far we operate
