What do you think of my build
VvsatanvV
Joined
Sep 25, 2009
Messages
Reaction score
Points
HI IVE JUST BUILT THIS PC FOR MYSELF AND WANTED TO KNOW WHAT YA ALL THOUGH OF IT PLEASE:
HERES THE SPECS :)
Core Features
CoolerMaster Storm Scout Case
Features
  • Fierce exterior design inspired by military weapons.
  • Reinforced carrying handles for fast and efficient mobilization.
  • Menacing all black interior and window side panel for striking visuals.
  • Stealth panel for tuning your lights.
  • StormGuardTM - ground-breaking security system for safeguarding your gaming peripherals.
  • Expansion Slots - 7 Standard and 1 Special
Specifications
  • Material: Steel, ABS Plastic, PC, Mesh bezel
  • Dimensions: (D)489 x (W)219 X (H)495.5 mm, (D)19.2 x (W)8.6 x (H)19.5 inch
  • Net Weight: 8.7 kg / 19.23 lbs
  • M/B Type: Micro-ATX/ATXBays
    • 5.25" Drive Bay: 5 Exposed (without the use of exposed 3.5 inch Drive Bay)
    • 3.5" Drive Bay: 5 Hidden, 1 Exposed (converted from one 5.25 inch Drive Bay)
    • 2.5" Drive Bay: 1 Hidden (converted from one 3.5 inch Drive Bay)
    Cooling System
    • Front: 140mm Red LED Fan x 1 (included)
    • Top: 40mm Fan x 1 (included) or 120mm Fan x 1 (optional)
    • Rear: 120mm Red LED Fan x 1 (included)
    • Side: Acrylic window; supports
    Gigabyte GA-EX58-UD3R Motherboard
    CPU
    • Support for an Intel® Core™ i7 series processor in the LGA 1366 package
    • L3 cache varies with CPU
    QPI
    • 4.8GT/s / 6.4GT/s
    Chipset
    • North Bridge: Intel® X58 Express Chipset
    • South Bridge: Intel® ICH10R
    Memory
    • 4 x 1.5V DDR3 DIMM sockets supporting up to 16GB of system memory
    • Dual/3 channel memory architecture
    • Support for DDR3 2100+/1333/1066/800 MHz memory modules
    Audio
    • Realtek ALC888 codec
    • High Definition Audio
    • 2/4/5.1/7.1-channel
    • Support for S/PDIF In/Out
    • Support for CD In
    LAN
    • 1 x Realtek 8111C chips (10/100/1000 Mbit)
    Expansion Slots
    • 2 x PCI Express x16 slots, running at x16 x16
    • (The PCI Express slots conform to PCI Express 2.0 standard.)
    • 1 x PCI Express x4 slot
    • 2 x PCI Express x1 slot
    • 2 x PCI slots
    Storage Interface
    • South Bridge:
    • 6 x SATA 3Gb/s connectors (SATA2_0, SATA2_1, SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 6 SATA 3Gb/s devices
    • Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
    • GIGABYTE SATA2 chip:
    • 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
    • 2x SATA 3Gb/s connectors (GSATA2_0, GSATA2_1) supporting up to 2 SATA 3Gb/s devices
    • Support for SATA RAID 0, RAID 1 and JBOD
    • iTE IT8720 chip:
    • 1 x floppy disk drive connector supporting up to 1 floppy disk drive
    IEEE 1394
    • T.I. TSB43AB23 chip
    • Up to 3 IEEE 1394a ports (1 on the back panel, 2 via the IEEE 1394a brackets connected to the internal IEEE 1394a headers)
    USB
    • Integrated in the South Bridge
    • Up to 12 USB 2.0/1.1 ports (8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
    Internal I/O Connectors
    • 1 x 24-pin ATX main power connector
    • 1 x 8-pin ATX 12V power connector
    • 1 x IDE connector
    • 8 x SATA 3Gb/s connectors
    • 1 x CPU fan header
    • 3 x system fan headers
    • 1 x power fan header
    • 1 x North Bridge fan header
    • 1 x front panel header
    • 1 x front panel audio header
    • 1 x CD In connector
    • 1 x S/PDIF In header
    • 1 x S/PDIF Out header
    • 2 x USB 2.0/1.1 headers
    • 1 x IEEE 1394a headers
    • 1 x serial port header
    • 1 x power LED header
    • 1 x chassis intrusion header
    • 1 x clearing CMOS jumper
    Back Panel Connectors
    • 1 x PS/2 keyboard port
    • 1 x PS/2 mouse port
    • 1 x coaxial S/PDIF Out connector
    • 1 x optical S/PDIF Out connector
    • 2 x IEEE 1394a port
    • 8 x USB 2.0/1.1 ports
    • 1 x RJ-45 ports
    • 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
    I/O Controller
    • iTE IT8720 chip
    H/W Monitoring
    • System voltage detection
    • CPU/System/North Bridge temperature detection
    • CPU/System/Power fan speed detection
    • CPU overheating warning
    • CPU/System/Power fan fail warning
    • CPU/System fan speed control
    BIOS
    • 2 x 16 Mbit flash
    • Use of licensed AWARD BIOS
    • Support for DualBIOS™
    • PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
    Unique Features
    • Support for @BIOS
    • Support for Q-Flash
    • Support for Dual BIOS
    • Support for Download Center
    • Support for Xpress Install
    • Support for Xpress Recovery2
    • Support for EasyTune
    • Support for Dynamic Energy Saver Advanced
    • Support for Time Repair
    • Support for Q-Share
    Bundle Software
    • Norton Internet Security (OEM version)
    Operating System
    • Support for Microsoft® Windows Vista/XP/Windows 7
    Form Factor
    • ATX Form Factor; 30.5cm x 24.4cm
    Intel® Core™ i7 920 2.66GHz
    • Desktop Processor Type
    • Core i7 Series
    • LGA 1366 CPU Socket Type
    • Nehalem Core
    • Quad-Core
    • Operating Frequency: 2.66GHz
    • 8MB Intel Advanced Smart Cache
    • Memory Type & Speed: DDR3 800/1066MHz
    • Intel® QuickPath Interconnect: 4.8GT/s
    • Intel Hyper-Threading Technology
    • Intel Turbo Boost Technology
    • Manufacturing Tech 45 nm
    • Cooling Device Heatsink and Fan included
    • 3 years limited Manufacturer Warranty
    Corsair 750Watt PSU
    • Supports ATX12V v2.2 standard and older ATX12V 2.01 spec
    • Supports Dual Core CPU, ATI CrossFire,Nvidia SLI and all Multi-GPU technologies.
    • Ultra-quiet 140mm double ball-bearing fan delivers excellent airflow
    • 80%+ energy efficiency at 20%, 50% and 100% load condition for less heat generation and lower energy bill
    • 99% Active Power Factor Correction provides clean and reliable power to your system
    • Universal AC input 90~264V automatically scans and detects the correct voltage
    • Dedicated single +12V rail offers maximum compatibility with latest components
    • Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety to your critical system components
    • High quality Japanese capacitors provide uncompromised performance and reliability
    • Extra long cables support full tower size chassis
    • TX750W Dimension: 5.9"(W) x 3.4"(H) X 6.3"(L);
    • MTBF: 100,000 Hours
    • NVIDIA SLI™-ready certified & Crossfire certified
    Noctua NH-U12P Special Edition i7 Fan & Heatsink
    Specifications
    • Socket compatibility: Intel Socket LGA1366
    • Height (without fan): 158 mm
    • Width (without fan): 126 mm
    • Depth (without fan): 71 mm
    • Height (with fan): 158 mm
    • Width (with fan): 126 mm
    • Depth (with fan): 95/120 mm
    • Weight (without fan): 600g
    • Weight (with fan): 770/940g
    • Material: Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
    • Application: all Intel Core i7
    • Fan compatibility: 120x120x25mm / 120x120x38mm
    • Scope of Delivery: 2x NF-P12 premium fan
    • Ultra-Low-Noise Adaptor (U.L.N.A.)
    • Low-Noise Adaptor (L.N.A.)
    • NT-H1 high-grade thermal compound
    • SecuFirm2™ Mounting Kit for LGA1366
    • Warranty: 6 Years
    Fan specifications
    • Model: Noctua NF-P12
    • Bearing: SSO-Bearing
    • Blade geometry: Nine Blade Design
    • Rotational Speed (+/- 10%): 1300 RPM
    • Rotational Speed with L.N.A. (+/- 10%): 1100 RPM
    • Rotational Speed with U.L.N.A. (+/- 10%): 900 RPM
    • Airflow: 92,3 m³/h
    • Airflow with L.N.A.: 78,5 m³/h
    • Airflow with U.L.N.A.: 63,4 m³/h
    • Acoustical Noise: 19,8 dB(A)
    • Acoustical Noise with L.N.A.: 16,9 dB(A)
    • Acoustical Noise with U.L.N.A.: 12,6 dB(A)
    • Input Power: 1,08 W
    • Voltage Range: 12 V
    • MTBF: > 150.000 h
    Corsair XMS3 6GB (3x2GB) DDR3 1600MHz
    • 6144 Megabytes of DDR3 memory
    • Three matched 2GB modules
    • 100% tested at 1600MHz in X58-based motherboards
    • Each three module set is tested at 1600MHz
    • Packaged together immediately following system test
    • Tested together at 1600MHz, Vdimm = 1.5V, at latency settings of 9-9-9-24 on X58-based motherboards with a Core i7 CPU
    • SPD programmed at: XMP 9-9-9-24 values at 1600MHz, 1.65V & JEDEC standard 9-9-9-24 values at 1333MHz
    • Supports Intel Extreme Memory Profiles (XMP)
    • Lifetime warranty
    WD VelociRaptor 300GB SATAII 10,000RPM Hard Drive
    • Capacity: 300GB
    • Cache: 16MB
    • Interface: SATA-II
    • Spin Speed: 10000RPM
    • Seek Time: 4.2ms
    • Warranty: 5 Years
    1TB 7200RPM SATA II
    LG Internal Blu-ray Re-Writer Disc/DVD/CD Combo Drive
    • 6x BD-R, 3x HD DVD Rom, 16x DVD+R/-R, Serial-ATA
    nVidia GeForce GTX 295 1792MB
    Performance
    • GPU: Dual NVIDIA® GeForce® GTX 295
    • Core Clock: 576MHz
    • Shader Clock: 1242MHz
    • Shader Model: 4.0
    • Texture Fill Rate: 92.2 Billion/sec. (Combined)
    • Processor Cores: 480 (Combined)
    Memory
    • Video Memory: 1792MB (Combined)
    • Memory Type: GDDR3
    • Memory Data Rate: 1998MHz
    • Memory Interface: 896-bit (Combined)
    • Memory Bandwidth: 223.8GB/sec. (Combined)
    Connections
    • Bus Type: PCI Express® 2.0 (Backward compatible with PCI Express®)
    • Display Connectors: 2 Dual-Link DVI-I, HDMI™ Out
    • RAMDACs: Dual 400MHz
    • Multiple Monitor Support: Yes
    • HDCP Capable: Yes, Dual link (Requires other compatible components which are HDCP capable. Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc and HD DVD formats, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays)
    • HDMI™ Capable: Yes
    • NVIDIA® SLI® Support: Yes, Quad
    • BFG NVIDIA® GeForce® GTX 295 1792MB graphics card
    • Quick install guide
    • DVI to VGA adapter
    • HDMI™ cable (6 ft.)
    • S/PDIF audio cable (1 ft.)
    • Dual 4-pin peripheral to single 6-pin PCI Express® power adapter
    • Dual 6-pin PCI Express to single 8-pin PCI Express® power adapter
    • Driver CD, which includes: NVIDIA ForceWare unified graphics drivers and Full Multiple Language Installation Manual.pdf
    iiyama E2607WS 26" Widescreen Monitor 1920x1200 2m/s
    PanelTN Diagonal26" Display area h x w343.8 x 550.1 mm Response time2 ms Contrast4000 : 1 ACR Brightness300 cd/m² typical Viewing zonehorizontal/vertical: 170°/150°; right/left: 85°/85°; up/down: 80°/70° Display colour16.7 million Pixel pitch h x v0.2865 x 0.2865 mm Native resolution1920 x 1200 (2.3 megapixel) Horizontal sync31 - 80 KHz Vertical sync56 - 75 Hz Analog input connectorD-Sub Digital input connectorDVI-D, HDMI SynchronizationSeparate Sync Plug & PlayVESA DDC 1/2B™ Speakers2 x 5 W (Stereo) Included accessoriesPower Cable, D-Sub Cable, DVI-D Cable, Audio cable, user manual, stand Apple - MacAll iiyama monitors are compatible with Apple-Macintosh computers. ControlsVia OSD in 9 languages (EN, FR, DE, ES, IT, FIN, Chinese (simplified and traditional) and 5 front controls (Menu/Input Select, Scroll down/Brightness/Contrast/ACR/ECO, Scroll up/OptiColour Mode, Select/Input Select, Power) User controlsauto adjust, contrast, brightness, ACR, ECO, input select, audio adjust, colour adjsut, information, manual image adjust (horizontal size, H/V position, fine tune, sharpness, video mode adjust, OptiColour mode), setup menu (language select, OSD position, OSD time out), memory recall DriverWindows 95 / 98 / 2000 / ME / XP / Vista SafetyCE, TUV/Baurt, VCCI-B, FCC Power supplyAC 100 - 240 V, 50 / 60 Hz Power Supply Unitinternal Power usage52 W typical; max. 2 W in Power management mode Power managementVESA DPMS, ENERGY STAR® Anti-theft-deviceKensington-lock™ prepared VESA mounting200 x 100 mm Tilt angle20° up Dimensions w x h x d597.5 x 460.5 x 238 mm Weight8.3 kg Aspect ratio16 : 10 Logitech MX 5500 Revolution Wireless Keyboard & Mouse
    • Logitech® Bluetooth® MX™ 5500 Keyboard
    • Logitech® Bluetooth® MX™ Revolution Laser Mouse
    • USB Bluetooth® mini-receiver (can be used as Bluetooth® hub)
    • Rapid-charging base station
    • AC power adapter
    • 4 AA alkaline batteries
    • CD with software, comfort guidelines, and help centre
    • Quick-Start guide
    Creative Sound Blaster X-Fi Xtreme Audio
    Technical Specifications
    • Playback: 24-Bit/96kHz 7.1
    • Signal-to-Noise Ratio: >108dB (20kHz Low-pass filter, A-Weighted)
    • Total Harmonic Distortion + Noise at 1kHz: 0.006% (20kHz Low-pass filter)
    • Recording: 24-bit/96kHz
    X-Fi Technology
    • X-Fi Crystalizer
    • X-Fi CMSS-3D Virtual
    • X-Fi CMSS-3D Headphone
    Connectivity
    • Speaker and Headphone connections for stereo to 7.1 (Line Out via three 3.5mm mini jacks)
    • Line In / Microphone In / Digital Out / Digital I/O (shared 3.5mm FlexiJack)
    • Auxiliary Line level Input (via 4-pin Molex connector)
    • Intel HD Audio Compatible Front Panel Header (2x5pin)
    Creative Inspire A500 5.1 Speaker System
    General Specifications
    • Speaker Power: 6 Watts RMS per channel (5 channels)
    • 17 Watts RMS subwoofer
    • Frequency Response: 45Hz ~ 20kHz
    • Bass level control
    • On/Off & volume located on wired remote control
    Features
    • Powerful ported subwoofer for realistic, explosive bass
    • Bass level control at subwoofer for personalised preference
    • Slim and elegant - designed to complement your desktop
    • High-quality speakers for clear music and speech
    • Magnetically-shielded satellite speakers do not interfere with monitor display
    • Wired remote with front-access controls for volume and power, with LED indicator
    802.11g WiFi PCI adapter
    • IEEE 802.11g/b standard for 2.4 GHz Wireless LAN
    • 64/128 bit WEP encryption, support WPA for security
    Internal Card Reader 26 in 1
    • Supports Compact Flash, Micro Drive, Smart Media, Secure Digital, Multi Media, Memory Stick, Memory Stick Pro, Magic Gate Memory Stick, Memory Stick ROM
    • Adds one front USB 2.0 port to the front panel of your PC
    :hiya:
Welcome to the forum :). Your build looks very nice - well done.
Recommend leaving out detail BS descriptions on your next post. Most people know what a speaker system or a mouse is!
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
