What do you think about these specs?
Discussion in 'AV Receivers & Amplifiers' started by molli, Jan 2, 2004.
  1. molli
    molli
    http://hem.passagen.se/erix15/skit/tekspectitan500.htm
    They are Swedish,but i think you can figure out main points of them.
    First comes to mind that 1% THD distortion at 1kHz,because if look some other receivers they are exp. like 0.06%THD at whole 20HZ-20Khz.
    Then i watched Pioneer´s VSX-D812-K specs and they look almost as "bad" as these what i asking for?
    Stereo (DIN) 2 x 100 W (8 Ohm, 1% THD, 1 kHz)(I put only Stereo here)
    http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=3770&taxonomy_id=62-98
    And what about Frequency Response: LINE that is LINE: 10 Hz – 70 kHz, +1/-3dB
    Usually this is like 5 - 100.000 Hz, +0 / -3 dB
    I´m little bit newbie for AV things,but I´ll be grateful if someone can clarify these spec things for me?
  2. molli
    molli
    Ok,let´s ask this way?
    What do you think about this receiver Centrum Titan 500?
    It´s cost 199 euro in Germany.It´s 6 ch receiver,support Dolby Digital EX, Dolby Pro Logic II, DTS-ES Discrete 6.1, and DTS Neo:6 audio formats.
    So features are good at this price point,but what about above spec things,how it sounds and general functionality+parts stability etc?
    http://www.netonnet.de/item.asp?iid=49933
