What do you think about the Triangle Antal ES?
Discussion in 'Home Cinema Speakers' started by SRam, Sep 29, 2004.
  1. SRam
    SRam
    For a 50/50 HC Hi fi use?
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,200
    2
    +3,674
    Bright sounding but great detail and transient speed (by which I mean there is no "overhang" between notes at all). Usually very sensitive to boot. If you are buying and using them in the UK I warn you that the UK distribution base seems a bit pap. I listened to them at the Mondial Show in Paris last year and I though they were brill.
  3. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    Triangles are very nice speakers and as Tons has already said, they are usually very sensitive.
    This makes them ideal partners for low powered valve amps, which is where I heard my first pair of Triangles (partnered with a Pathos).
    The sound was breathtaking.
