Quantcast
what do you guys reckon a 36" tv will be worth
B
backtothefuture
about 1.5 yrs from now... having ordered one, just want to know likelihood of recovering price
its a £1400 Philips 9618
do you reckon the advances in Plasma screens by then will more than halve its value?
I was considering renting the above at £17.50 per week but it works out at 910 per year , so I thought I may as well buy it and sell it later!
jason_one
i've seen a 2 month old 36" philips go for £500 18 months a-go!
but looking like £600-£900 now
1.5 years from now would be £400-£700?
B
backtothefuture
hm ok, that means buying it is £400-700 cheaper than renting it over 1.5 years
the 9618 can be rented for £17.50 per week
jason_one
if i were you i would buy someyhing cheaper say:samsung 32" 100hz pure flat ws32z46vs £499.99 www.be-direct.co.uk
renting is costly and i would only do-it if for less than 10 months anything other 10 months is half way to a new tv
you could sell the samsung for £200-300 easy
thats less than £4 a week for you .
when plasmas and lcd prices half then you can buy one with the money you'll save
but seeing you have a philips tv on the way its a bit late to send the tv back now.
B
backtothefuture
well its on the way
i did consider 32" tvs since there are a lot of good deals on them however that extra 4" adds more viewing fun ... dont know whether the premium paid for those is worth it yet!
