What do you get for £50 installation on sky+
Discussion in 'Sky Digital TV Forum' started by davepuma, Jun 26, 2004.
  1. davepuma
    davepuma
    Jun 24, 2004
    17,502
    +3,495
    What are Sky charging £50 for installation for with Sky+? Surely if you've already got Sky, it's just a case of swapping the boxes over? I am interested in getting Sky+ but the 20Gb HDD and the limited 5.1 sound are putting me off. I had considered a Panasonic HDR/DVD-R instead but I suppose the fact that Sky+ is easy to use (??) is probably a better bet. I would then add a DVD recorder (DMR-E55) to complete the set up.
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    davepuma - As always, it pays to do a little research before asking a question.
    It took me less than a minute to discover Sky+ is now £149 + £10 installation if booked online.
    Many people have reported numerous problems with Sky+ but I have had nothing major. It is prone to irritating software bugs though. As Starburst says in another thread, the reliability is probably dependent on the quality of the installation, something I agree with completely.
    As for the HD, it's 40Gig, not 20. The box will record around 20 hours, if you need more than that - you're watching far too much TV :devil:
    Also, Sky+ requires 2 feeds from your dish hence the need for a second cable run. £50 for this work (if done properly) is a bargain. £10 is for nowt! (almost!!) :laugh:
    A. Dork
  3. davepuma
    davepuma
    Jun 24, 2004
    17,502
    +3,495
    Thanks for the reply. I can't find the £149 offer. It was deffo listed as £199 the other day when I looked. I have tried to order online but it says they can't and I've got to ring a number. I'll try again later as if you order over the phone they charge more (apparently). So, basically they're charging for running a 2nd cable from the LNB to the box. If that's it, I could do it myself, although £10 is a bit of a steal.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Well look at it like this.
    They are either throwing in a Quad LNB for free with the SKY+ itself or the installation charge covers the supply and fitting of the new LNB including dish alignment check and new cable. They will even replace the dish at no extra cost if they consider it to be of poor quality.
    Considering the Quad LNB itself retails for around £50 and then there is the cost of labour then it's not a bad deal either way:)
  5. chilpillphil3
    chilpillphil3
  6. Stewart Howie
    Stewart Howie
    Jul 3, 2003
    289
    Scotland
    +3
    Aye but try ordering it for that it immediately reverts back to the old price, i'm going to try to spend some complaining time today to see if I can get the offer
    It does appears to be for new customers only however.
