What do we make of these?
Discussion in 'Home Cinema Speakers' started by CarBoy, Dec 21, 2006.
  1. CarBoy
    CarBoy
    Nov 7, 2006
    33
  2. CarBoy
    CarBoy
    Nov 7, 2006
    33
    Anyone?? :lease:
  3. Shakti
    Shakti
    Mar 16, 2006
    24
    Thats gone. I am not going to tell you who bought it.
  4. CarBoy
    CarBoy
    Nov 7, 2006
    33
    Do what?? What do you mean? I'm aware that the auction has finished, but there were no bids. Are you the seller??
  5. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Don't worry, you didn't want them. Even if you did.
    Russell
  6. CarBoy
    CarBoy
    Nov 7, 2006
    33
    Thanks. :smashin:
  7. hoppaz
    hoppaz
    Oct 1, 2005
    1,916
    +225
    They look very similar to these...
    http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=6346
    I heard them at a "home show" at Earl's court earlier in the year. They sounded good for the money (I think they were £650). I also think they sometimes advertise in What Hifi.
    Hope this helps
  8. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Go for a demo if you're local. They're back on if you're interested.
    @Russ- are they rubbish? Don't be enigmatic, tell us like it is ;)
  9. Nimby
    Nimby
    Jan 27, 2004
    9,207
    The Danish Bacon Factory
    +671
    I really don't like the sunken drivers. Given the frequencies being handled I would imagine these short rings would produce a distinct HF pipe resonance. I like loudspeaker designs that place an emphasis on exposing the drivers to the maximum degree in a baffle as narrow as possible to avoid diffraction effects. The drivers are also rather small for moving large quantities of air in an AV system playing at high levels. This would require very long throw drivers with higher distortion levels likely in comparison with larger drivers for the same SPLs. The need for speaker headroom in film watching should not be underestimated. The purchase of a decent subwoofer would have some speaker systems quickly running out of steam on dynamic effects. The sub can't do it all.
