You have confirmed pretty much what I thought since reading your very first post, which is that you are essentially wasting everybodies time, and that this is really nothing more than a troll thread… Because it honestly does appears that all you’re really interested in doing here is, telling others based on your extremely limited experience with object based audio, that you believe it’s basically a gimmick, and are more looking for others that share this opinion to reassure you about your views which you feel you have already established regarding Atmos and DTS:X.
And thank you for mentioning 3D and HDR comparing those to this in your post too, reinforcing the impression I already had of you based on what you have said (I was intending to bring that up, making a joke about it at your expense about how you likely think those are gimmicks as well)… I would’ve easily guessed that you were likely one of those type of people long before you said it, who likely often believes that almost every newish tech in the world of home theatre are gimmicks, and over the years you’ve probably started similar threads on sites like this to say the same about 3D and HDR etc too.
I didn’t confirm anything at all… It seems like you have already made up your mind, and you are simply trying to find things in comments that supports this and your agenda. Nowhere did I say that the technology is used to it’s full potential in every case, however I didn’t state that it is rarely used to it’s full potential either… It’s been pointed out to you by others that the quality of this can greatly depend on the mix (plus other variables), and this same issue is not exclusive to Atmos/DTS:X tracks. There are plenty of 5.1/7.1 lossless tracks that you could say the same about, which have been mixed poorly, and don’t utilise all of the speakers in these configurations well… If you disagree, then just like in this situation with Atmos/DTS:X, you clearly don’t have as much experience comparing these things as you think you do.
Based on some of the things that you have said in this thread, your setup doesn’t sound like it’s adequate to me, and it seems like you don’t really want to spend money on the content… Your viewing of The Matrix Resurrections, and your free demos which didn’t “wow” you, are a long way from being enough to cut it for you to be able to make a creditable determination, and for you to be boisterous about these experiences, using them to inform others about any true shortcomings…
