What do people use to hold up their projector?
Discussion in 'Projectors, Screens & Video Processors' started by tomacwhite, Jun 12, 2004.
  1. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    After 6 months of happy use, I love my AE200 projector to death and couldn't live without it. I am currently using a portable TV wall bracket to hold the projector to the wall in upside-down mode. Getting this to be an absolutely perfectly level (ie a straight image) is virtually impossible.
    Even just a slight mis drill to the left a little bit could make the wall braket not sit so perfectly. And obviously using it upside down means you can't use the adjustment legs on the projector. I have resulted in using little sticky pads to level the image out, and although its not to-the-degree perfect, its good enough and works fine.
    I was just wondering what other people use? Do you use the official or 3rd party ceiling drop kits to hang the projector? Or a table perhaps? Or like me do you use a TV wall bracket?
    I was having a fiddle with it tonight, and I am not sure whether to live with it until I can have a dedicated room, or try and sort something out..
    Thanks,
    Tomac
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Visit the FAQ for links to instructions on making a ceiling mount for your projector, or consider one from LMP or Nexnix......
    Home-made job here, not desperately pretty, but does a perfect job.......
    Sean G.
  3. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    I use a set of those adjustable shelf brackets from B&Q. Used the largest and have just enough room to the rear for taking cables in/out and make sure to use the screw holes in the brackets, we dont want any accedents do we. :rolleyes:
  4. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
  5. doink
    doink
    I use a unicol mount sprayed silver
  6. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Another vote for LMP. They really do have an excellent build quality.
  7. Paul D
    Paul D
    Dec 27, 2000
    2,741
    Manchester
    +537
    I use a LMP mount, and think it is fantastic and great value.
    Maybe you could use some washers between the mounting screws and bracket. It might mean a bit of trial and error, but once done shouldn't need further attention. :smashin:
  8. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,220
    UK.
    +2,760
    There are a couple of cheap speaker bracket versions here:
    http://www.g-lightfoot.pwp.blueyonder.co.uk/ht1000.html
    I've just recently made another ceiling mount which uses two pieces of 6mm MDF and three adjuster scews. I needed to make it to accomodate my anamorphic lens, but can be used for any pj. It mounts the pj straight to the ceiling more or less, so there is no drop down tube. I'll post pics of that on my site sometime too.
    It's basically a two pieces of MDF the same size as the pj, but with with three 'ears' that are for the adjusting screws. One at the front, and one each side at the rear. Along with some slots at the back (in the MDF piece that mounts to the pj), the screws allow adjustment in all plains incluidng sideways swivel to line up with the screen.
    HTH
    Gary.
  9. The Dude
    The Dude
    May 21, 2004
    6,337
    Beverley, East Yorkshire
    +2,693
    A plank of wood hanging from the cieling timbers on 3 long coach screws..
    works as per gary lightfoot's post really.. just a bit simpler to do
    Fix the rear screw first, line up laterally, fix the 2 front screws, then use all 3 to get drop angle correct..
    Cost all of £6 and done in 20 mins..
  10. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,220
    UK.
    +2,760
    That sounds great - can you post some pics so others can see how it work etc?
    Cheers.
    Gary.
  11. The Dude
    The Dude
    May 21, 2004
    6,337
    +2,693
    dont have a cam so cant do piccy's, but it's so simple that a drawing will get the idea across..
    I'll put something together and post shortly..
  12. Zone
    Zone
    Jun 24, 2001
    6,754
    Barnsley
    +2,459
    Pany300 upside down on a shelf high up: rubber spacers underneath to give a bit of ground clearence and to help in levelling it :thumbsup:
  13. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,220
    UK.
    +2,760
    Here's a pic of my idea - not as simple as Dudes, but still very simple.
    You attach the pj to the bottom piece of MDF. The top part is fixed directly to the ceiling.
    Gary.
  14. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    vote for lmp mount from me ,great piece of kit
  15. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    Yep, I bought one of these and it was simplicity itself to put up, once I'd worked out what I was doing :laugh:
    Highly recommended :smashin:
  16. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    Cheers guys for all the info..
  17. pez
    pez
    May 1, 2004
    776
    Newport
    +27
    ive got my ptae500 on a camera tripod. easy to hide away when not in use, and portable too!
    pez
  18. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Z2 on a wall mount for a vcr for me. Think it was about £14 from B&Q.
  19. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    I use a portable TV bracket from a well known DIY chain, mounted on the back wall upside down.
    The one I have is adjustable for tilt, left, right, back and forward, gets over the problem of not getting the position of the mounting plate exactly square
  20. nero0410
    nero0410
    Jan 5, 2004
    12,138
    Weston Super Mare, UK
    +4,647
    I simply use a bedside cabinet and set it up before use and put it away inside the bedside cabinet after. Nice and simple for me.
    tris
  21. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,220
    UK.
    +2,760
    Here's a pic of Dudes mount:
    He or I can email instructions if you need them, but the length is designed to fit onto the ceiling joists, so should be reasonably universal (concrete notwithstanding).
    EDIT - I've added the instructions, so provided their readable after resizing to 500 wide, it's all here.
    Gary.
  22. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    Mine is currently on my av rack but will ceiling mount once i move into another room.
    They are good instructions gary i think that i will use those when i come to ceiling mount mine.
  23. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    Nice one, Gary :)
  24. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    pics of mine in my sig, very cheap to do and doesnt impose when not in use :)
  25. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    Mad Andy
    That is a great looking stand, looks like one I could even sell to the wife.
  26. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    aye, made it for £6 :D Installed the screen first, then measured up dead centre to screen and marked this position on the opposite wall, then put up the 'mount' then made the others around it just to look a bit fancy lol but didnt want to hang it from the ceiling due to the keystoning needed as ultimately, dead centre is best image as per the pics further down below
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  27. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
  28. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,220
    UK.
    +2,760
  29. xxalxx
    xxalxx
    Dec 15, 2003
    230
    Perth - Australia
    I made mine out of an old sky analgue sat dish, took the disk off the clamp, attacked it with a hack saw, put a peice of perspex on, voila :clap:
    Al
  30. Darwock
    Darwock
    £13 microwave bracket out of argos. I didn't have the money or space for anything more complex.
