What Do I need?
Discussion in 'AV Receivers & Amplifiers' started by MELUN, Dec 23, 2003.
  1. MELUN
    MELUN
    After some help please people.
    I have a Tosh 36" Widescreen TV , Sky+ and about to get a Panasonic HS2.
    I currently have a Videologic DTS 5.1 surround sound unit , however would like to get rid of this and get a decent amp/reciever to hook up to my speakers. I will then upgrade the standard tosh speakers in due course.
    Can anyone advise what sort of thing I should be looking at ? as I have no real knowlegde in this field.............
  2. Rolo Tomasi
    Rolo Tomasi
    Dec 13, 2002
    215
    +4
    Depends upon your budget, space available, music/movies priorities etc.
    Sorry to be so negative but options are so many these days that more info. is needed.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  4. MELUN
    MELUN
    I am considering the Yamaha HTR5630 , as for £150 it looks
    like a good starting point? i.e. it has all the connections and features for a first attempt at a home cinema etc
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    superb place to start mate!
    What will you be connecting?
  6. MELUN
    MELUN
    Toshiba 36Z18P Picture Frame TV
    Sky +
    Panasonic HS2
    Only standard Tosh speakers with TV to start with............
    May shell out and get some of the Yammy Speakers though?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    If thats the case a package deal willbe better value as the standard speakers arent going sound any better (well not £150 better) with the amp stretch to £250ish and a package can be had yam do one with that amp and speakers or check out richersounds for bargain speaker packages
