What do i need to "go live"
Discussion in 'Xbox Forums' started by Adrenochrome, Oct 29, 2005.
  1. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,052
    Babel Sensurround
    +211
    Hi Mrs Chrome has come in with the Halo2 and live subscription pack for me last week :thumbsup:
    What do i need to buy to set this up?
    I have my host pc in the bedroom feeding a shuttle in the cinema room (wired) and a desktop in my daughters room (also wired)
    Help in plain non jargonised English would be beneficial :D
    Adrenochrome.
  2. mal60908
    mal60908
    Have you got a router?
    If not, it is best to get a router, wired or wireless, the Netgear ones are a good start.
    DG834 - is my router (non-wireless, but you can add a wireless access point at a later date, like I have)
    DG834G - is 54mbps wireless router
    DG834GT is 108mbps wireless router
    The easiest way is to run an ethernet cable from your xbox to your router, with any of the above routers.
    If you go wireless you just need need a wireless bridge for your xbox (Netgear WGE111) along with one of the above wireless routers (834G or 834GT)
    Easy peesey...instructions are with the routers.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    23,033
    London
    +1,157
    Also, make sure the ethernet cable you use from your router to xbox is 'Straight' cable and not 'Crossover' cable.
  4. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,052
    Babel Sensurround
    +211
    I Have a router so i guess this is a start :)
    Where would i buy a straight cable from?
  5. Tejstar
    Tejstar
    Dec 4, 2002
    23,033
    London
    +1,157
    Try Maplin's, PC World, Dixons or even your local Game. :)
  6. Pooon
    Pooon
    Dec 26, 2002
    7,576
    Canterbury, Kent
    +1,228
    :rtfm: :D Inside your wonderful halo starter pack there are lots of pieces of paper stapled together, the first page of which is coloured black and says 'XBOX Live Instruction Manual' and on page 4 it tells and even shows you how to connect to live! :D
  7. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,052
    Babel Sensurround
    +211
    Haven't had the time to open it up yet :( But as sure as sh!t is sh!t i won't understand it anyway :D
