What do I need to connect two tvs and two Xbox 360s in the same room?
Discussion in 'Xbox Forums' started by Chris980, Jan 17, 2008.
  1. Chris980
    Chris980
    To save having to drill a hole in the ceiling, we're going to put the two tv's together in the same or adjacent rooms with the two consoles.
    I know how to connect the ethernet cable (it's only for two player at the moment), but it's just the tv connection I'm unsure about.
    Will a single splitter and two coaxial flyleads be enough, one running to either tv?
    No acronyms if you would!
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,037
    Bristol
    +9,750
    Can you not connect each 360 to each TV via the included cables?
  3. Desmo
    Desmo
    Jan 4, 2001
    14,562
    Braintree, Essex.
    +6,665
    I'm confused on what you want to do. If you've got two TV's and two 360's, surely you just connect each 360 to a TV and then join the 360's with ethernet. Why are you trying to split a TV signal?
  4. Barry the Brave
    Barry the Brave
    Feb 15, 2007
    451
    28
    +62
    If you're talking about splitting a coaxial lead are you referring to splitting the analogue aerial input (for analogue tv reception) so that it reaches both TVs? :confused:
  5. kaidiez
    kaidiez
    Nov 20, 2007
    385
    28
    +28
    yep I also ponder the use of a splitter. All you need to do is connect your x360's to each tv and then ethernet cable between the 360's, multiplay enabled!
    To split your aeriel so both tv's can pick up normal tv, I am sure what you have suggested will work fine, why you would want to watch tv is beyond me tho :p
  6. Barry the Brave
    Barry the Brave
    Feb 15, 2007
    451
    28
    +62
    You've clearly never seen Top gear, sir!
