What do I need to connect an RGB Scart output to an MXE1 VGA(RGB) port?
Discussion in 'Plasma TVs Forum' started by calvinhobbes, Feb 9, 2005.
  1. calvinhobbes
    calvinhobbes
    As far as i can see, the MXE1 supports RGB via the VGA port, so do I just need a cable?
  2. nealgs
    nealgs
    not sure but maybe a JSTech RGB to VGA converter?????
    Gary
  3. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    As i understand it, it's either win or loose in this situation, you might be lucky and it works.
    I would recommend the JS Tech RGB2VGA instead as it will give you a sharper picture they say and smashin colors.
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    For a direct SCART connection from say a Sky box the MXE1 would need to accept an RGBs signal which AFAIK it doesn't.
    Cheers, Lee
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
