what do i need? plz read
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by swanytroon, Aug 12, 2004.
  1. swanytroon
    swanytroon
    Apr 4, 2004
    931
    +10
    ok if i buy an older av amp for example sherwood 945 which has 5.1 in what do i need get to upgrade the sound formats like proc logic 2?
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Well to add stuff like plII and DTS neo6 the only way I know of is to buy an amp that decodes these formats, in which case you'd throw the sherwood in the bin.
    Sorry as far as I'm aware there's no way of doing what you want, simply buy an amp that has the formats you require.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,502
    Edinburgh
    +1,237
    I concur. If you want Dolby PL2 processing then buy an amp/receiver/processor that has it. The Sherwood amp you speak of will be totally redundant and almost worthless with pace of the AV market these days, you might as well dump it or use it as a basic stereo amp on another system.
  4. swanytroon
    swanytroon
    Apr 4, 2004
    931
    +10
    ok thanks so what amp should i go for at about £150 i cant really spend anymore bt will look into 2nd hand
