What do i need ?!! Newbie..
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by ratmas, May 14, 2005.
  1. ratmas
    ratmas
    May 14, 2005
    I'm nearly finished with an 18 month trip around the world. At present i've got about 40 hours of footage that will need editing when i get back home in 3 months time. I have been using a sony trv80 . My question's to you whizzkids out there, are as follows.
    1. Could you tell me what comp setup i'll require, when i get home? 1000 pound max.
    2. What editing and dvd software will i require , not forgetting i'm a complete newbie..
    Thanking you in advance..
    www.ratmas.moonfruit.com
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    1. Any modern PC will do. Get as much RAM as possible, I would recommend at least 1Gb. A second hard disc to only contain the captured/edited video and no programs - 1 hour of DV quality footage will take up around 13Gb of space so get the biggest drive you can. Other than that just get a fairlty fast CPU (best you can afford), any DVD burner and make sure the PC has a firewire port to capture the video through. With £1k these specs should be easy!
    2. Windows XP has a good program for capture & editing called Movie Maker. Get all the MS updates and this will give you MM2. This will however not create a DVD, so get a good DVD authoring program such as Ulead Movie Factory for around £30.
    Mark.
