What DLP?
Discussion in 'General TV Discussions Forum' started by jgr11, Sep 1, 2005.
  1. jgr11
    jgr11
    Hello, I'm from Girona in Catalonia. I need some opinions to decide to buy Toshiba 52WM48, Loewe Articos 55, or Sagem 56H-HD.
    I'm like Toshiba in first moment, but a lot of opinions are not good...
    Another problem is the connection with PC via DVI, in toshiba is possible???
    Thanks!!!!!
  2. Mark_a
    Mark_a
    May 27, 2005
    3,062
    +611
    I bought a Tosh 52" but if I were buying now I'd buy the Sagem 56". Loewe stuff always strikes me as being similar to Bang & Olufsen - nice kit, very pretty, but stupidly overpriced.
    The Tosh doesn't have DVI in. It has a VGA socket and an HDMI socket, but DVI to HDMI adaptors are cheap and easily available. The Sagem doesn't have an HDMI but it does have an HDCP enabled DVI, so good enough.
    Regards
    Mark
  3. jgr11
    jgr11
    For what you now buy Sagem fot the size or the quality...??? :D :D thanks!
  4. jgr11
    jgr11
    Ok, the decision is between Sagem or Toshiba, 52'' vs 56'', PIP vs no PIP, but toshiba image is better than Sagem, no? and Toshiba have a HDMI direct...
    I don't know....
    plesa some help me...
    :) :D :) :D
  5. Grzenio
    Grzenio
    Apr 2, 2005
    17
    What about hot new HD4 models from Thomson: 61DLW616 or 50DLW616.
    They are priced very competitive.
    UK version is ...617.
  6. Riva
    Riva
    Mar 8, 2005
    19
    I have the sagem Hd-D56 and its a very good set in terms of picture quality connecivity and price. HD ready via DVI and a good looking set in its own right. For me its close to perfect, looking forward to viewing HD!! Hope this helps.
  7. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Mark sorry mate but I disagree, although I know where you coming from B&O is ***** and Lowe produce high end excellant quality gear. B&O is just pure styling and high prices. IMHO Lowe walks all over B&O.
    I would go for the Sagem 56 or Samsung 50' if your budget can stretch to a Optoma RD65 then grab one of these.
    :D
  8. jgr11
    jgr11
    Samsung is better than 52'' toshiba???
    In electronic shop I question for DLP products and they ask me than toshiba are very good DLP projector...
  9. Mark_a
    Mark_a
    May 27, 2005
    3,062
    +611
    Both. The Sagem wasn't available when I bought the Tosh. I think the Sagem looks to be better all round, though the Tosh is quite a bit cheaper. The Tosh also suffers from motion blurring on poor quality feeds, and isn't entirely free of it even with the best of conventional feeds. I suspect it will be a lot better with purely hidef feeds. I certainly get very good images from it with a Lumagen video processor that's as near to hidef as we get at the moment.
    Regards
    Mark
  10. Mark_a
    Mark_a
    May 27, 2005
    3,062
    +611
    Oh I agree that Lowe make excellent stuff. It's just deliberately overpriced to appeal to snobs who know no better. And they certainly end up with very good gear, even if they could have bought just as well for two thirds the money elsewhere.
    Regards
    Mark
  11. Chumpy
    Chumpy
    Loewe is nice but as many have mentioned - overpriced - somehow though it always seems to be cheap if you're in the Netherlands - dunno why exactly.
  12. jgr11
    jgr11
    Ok, thanks. I need view sagem and toshiba in some electronic shop and I buy one of these TV's... I put TV at 3 meters of the sofa, i don't know if 56'' is too big for this distance...???
  13. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    I would buy Lowe gear. :smashin: I know they are not cheap but they do offer very high quality. Lowe gear is always rated very highly something that B&O never really achive.
    I personally hate B&O. Rubbish over priced stylisd tat. [​IMG]
  14. rhawk
    rhawk
    I agree with Razor. My friend has the Loewe DLP and it amazes me every time I see it. Superb picture, very good viewing angle and fantastic looking. :thumbsup:
  15. Ruby
    Ruby
    Jul 27, 2001
    995
    28
    Coventry
    +82
    jgr11,
    I know how you feel. I myself am trying to decide between the Samsung 507LHX and Sagem D56B. At the moment, I'm favouring the Samsung for looks, price and HDMI connection (although I'm not really sure what the benefit is of having a HDMI instead of DVI connection). However, the Sagem has one advantage - the screen is 6 inches bigger.
  16. Mark_a
    Mark_a
    May 27, 2005
    3,062
    +611
    I've come to the conclusion you can never have 'too big'. And that's something me an' Razor can agree on! :)
    I view a 103" projector screen from 3m and have no problem at all. Apart from the Tosh 52" looks a bit too small when I raise the screen out of the way and go back to ordinary TV again.
    Regards
    Mark
  17. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    :hiya:
    103" sounds lovely. :D Mark is right when he says you can never go 'too big'
    :D
  18. jgr11
    jgr11
    DVI sagem is same that HDMI toshiba????
    Sure that Sagem is best choice, no... ???? :D :D
  19. Mark_a
    Mark_a
    May 27, 2005
    3,062
    +611
    The Sagem 56" would be my choice, for sure.
    Regards
    Mark
  20. jgr11
    jgr11
    In home Cinema Choice talk about Sagem 56'' vs Toshiba 52'' I'm very interessed in this article but i'm from spanish and don't found this magazine in my town, somebody can explain me the conclusions of the comparative... or this pages in pdf... thanks!!!!!!!!!!! very much.
    Moltes gràcies!!
