what dlp tv to buy
Discussion in 'TVs' started by big ric, Oct 9, 2004.
  1. big ric
    big ric
    Hi guys
    I am after some help from someone out there i have upto £3k to spend on a 50" dlp rear projection tv i have seen the sagem and liked it alot and going to see the thomson tomorrow what i would like to know if any one can help me which is the best set in regards future proofing i will not be using a pc on it so was thinking along the lines of sky HD, HD dvd i think the thomson does not have componet inputs but sagem does and the thomson has dvi with hdcp i think? anyone know for sure but the sagem as a pc dvi input is there any way i could use the dvi non hdcp input on sagem for watching HD sky or HD dvd maybe with the use of a switch box or somthing
    Thanx
    Big Ric
