what discs for sony 710 recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by sodgob, Oct 26, 2005.
  1. sodgob
    sodgob
    Help ! i am about to purchase a sony 710 dvd recorder can anyone tell me . is there any advantage in -R & +R discs
    i also want a supply of RW discs does the same apply .
    i also have a cheap 'asda' player which will only play pre recorder films .. would any of the above play on this also ?.
    thanks for your patience with a DVD virgin.
  2. johnmccoy
    johnmccoy
    Jan 25, 2005
    17
    Ballynahinch
    Generally speaking -r disc are supposed to be the most compatible with DVD players, also on the 710, if you record from a widescreen source e.g. Freeview or Sky, then only -r or -rw discs will record the widescreen switch that automatically sets the TV properly (assuming you watch TV in widescreen or are planning to in the future). You should format the discs as DVD-Video not DVD-VR which is the default setting on the Sony as DVD-Video is the same as standard DVDs and VR is only for editing which you will do on the hard disc drive before transferring to DVD anyway.
  3. ArtS
    ArtS
    By the way - you can set default format for DVD-RW Video Mode in setup menu. Disandvantage of -R/RW is that you have to finilize it manually after recording.
    ArtS :cool:
  4. sodgob
    sodgob
    Many thanks for your help guys ...greatly appreciated , cheers!
  5. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    I'm using Datawrite titanium -R and +R(DL)
    I'm still trying to establish whether the machine can do -R(DL)
