What Digi cam should I get? (to take pics and video)
Discussion in 'Photography Forums' started by wildbillmusic, Oct 14, 2003.
  1. wildbillmusic
    wildbillmusic
    Hello, Im looking for a digital Camera that has these features...
    Good for taking pictures outside
    Have a Visable Screen to view pictures on camera itself, and to take pictures
    Produce high qaulity pictures that can be transfered on to my PC via a USB
    Be able to capture short moving images (in good quality) and possible sound (if this is possible?)
    Have a good memory to store many pics/vids on it!
    Be supplied with a memory card/memory stick
    Be supplied with a case for outdoor/extreme use (can purchase seperarlty)
    Price range: Around £250
    Any suggestions?
    Also, is it even possible to get a digital camera that can capture moving images and maybee even Sound?
    Bill
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,268
    Rainham Essex
    +2,405
    Yes you can capture sound & moving images, but the quality is fairly low. If you want good quality video then your only real options is a camcorder. Camcorders are getting much better at taking stills, but the best quality comes from a dedicated unit.
    Memory cards can only write at a fairly slow speed so this keeps the quality for video low.
    Mark.
  3. wildbillmusic
    wildbillmusic
    I will be using the digi cam outside to take shots of my biking mates doing jumps etc, and I wanted to also get some movie shots to upload on to my pc so i can send them to people. I want good quality photos, and fairly good movies, it doesnt have to be perfect qaulity movies though, just good enuf to make out, you know. if anything, i will just be using the movies on the camera to look at.
    Any suggestions?
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Have a look at the Canon A70. 3.2mp, 3 x zoom, movies with sound. Excellent quality stills and amazing battery life.
    You should be able to pick one up for £225 or so. Add a 128mb compact flash card (£30 or so) which will capture 70+ images at the highest quality setting.
    Matt.
  5. aaronjon
    aaronjon
    check out the minolta Z1, 3.2mp, 10x optical, 4x digital, 3 levels of video with sound, top level 640x480 30fps. £280, 256mb sd memory card £54 will take around 300 mid res photos or around 12 mins mid res video at 15 fps.
  6. wildbillmusic
    wildbillmusic
    that looks up my street, bit expensive, but good, and im willing to shell out on that sort of thing. How good is the Video Quality? Can someone send me a video in '15 fps' Qaulity becuase im not sure what the means. Beatsfromthesun@aol.com
    What im really after is the digital camera that can take good average pictures, but do good movies as well. What the best camera for recording movies on around £300?
    Thanks for your adivce!
    Bill
  7. aaronjon
    aaronjon
  8. wildbillmusic
    wildbillmusic
    that camera look awsome! 30fps movies looks good too. How long can the movies be/ how much data can it store? Can you like buy a really good memory card for it or something?
    WB
  9. MarkE19
    MarkE19
    Aug 10, 2002
    17,268
    Rainham Essex
    +2,405
    This should help:
    Storage Capacity
    Approximate storage capacity of a 16MB SD (Secure Digital) Memory Card
    2048 x 1536/1600 x 1200/1280 x 960/640 x 480
    Fine 9 frames/14 frames/22 frames/69 frames
    Standard 17 frames/27 frames/39 frames/100 frames
    Economy 32 frames/47 frames/69 frames/150 frames
    Movie Clips
    640 x 480/320 x 240/160 x 120
    30 fps 13 sec/21 sec./1 min. 22 sec.
    15 fps 26 sec./41 sec./2 min. 30 sec.
    Movie clips recorded with audio.
    Actual number of images may vary depending upon the subject and memory card.
    Mark.
  10. aaronjon
    aaronjon
    it should take a 512mb sd card, around £155, you can take marks stats and x 32 for an estimate.
  11. wildbillmusic
    wildbillmusic
    This forum is propa! I’ve done the same thing on some others, but not as excellent response as this! Thanks to everyone, now all i got to do is do some over time work!
    My Final Question......
    ::confused: Can you recommend the best quality rechargeable batteries (with charger) for the Z1, like ones that will last a long time with this particular model.
    ::confused: Also, Can anyone recommend the best/cheapset 128MB SD card
    ::confused: Finally, a decent bag to keep it in, after all im taking it biking with me (a hard case or something?).
    Budget for all these accessories is strictly no more than £100.
    I’m thinking of buying the Z1 from Amazon as its quite cheap there, and its free delivery so if I can buy the accessories from hem that would be cool (I’m England Based)
    Cheers all, keep up the good work and if any of you want a chat sometime just ask.
    WB:smoke:
