What differeces are there (NTSC - PAL)
Discussion in 'Blu-ray & DVD Players & Recorders' started by whitty, Oct 9, 2001.
  1. whitty
    whitty
    Oct 9, 2001
    33
    NTSC vs PAL
    Hi.....
    This is my first post but have had a DVD player for a while. I have a Sony 735 player and Im thinking about getting it chipped from Techtronics...
    The Output is PAL > PAL and NTSC > NTSC.
    Is there any noticable difference between these two signals. My TV accepts NTSC on AV so If I buy a R1 disc when it is chipped the Output will be NTSC.......
    I have a Decent SCART cable and player is set to RGB.
    Thanks guys
    Rob
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,527
    Somewhere in South Yorkshire
    +6,000
    Differences between PAL and NTSC:
    1) The colour information is carried differently. This means that the TV has to be capable of understanding the NTSC colour signal; from what you say, yours is.
    2) The frame rate is different. On PAL, the frame rate is 25hz i.e., each full picture takes 1/25 second to display before moving on to the next. On NTSC it is 30hz. This means a faster refresh rate for NTSC. Unless you have a "100hz" TV you may notice this as reduced "flicker" on bright parts of the picture.
    3) The number of horizontal lines making up the picture is different. On PAL it is 625 (of which 576 are actually used for the picture). On NTSC 525 total, 480 used. This means that the vertical definition of an NTSC picture is slightly lower than on PAL although for practical purposes you are unlikely to notice any difference, unless you sit very close to a very large screen.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    No problem to be expected if the TV supports RGB or NTSC. R1 rulez! :D
