What db level is your Subwoofer?
Discussion in 'Subwoofers' started by dale001, Nov 1, 2001.
  1. dale001
    dale001
    What db level do you have your sub set at?
    I know VE suggests all speakers to be set at 75db, but I'm told many have the sub hot a few dbs to like 78, 79.
    Dale
  2. bob007
    bob007
    It`s all down to personal taste, iv`e seen suggestions about db settings some as low as 69db. I have mine set to 75db tried it higher/ lower, the higher setting to much bass and the lower setting not enough. Try and set it so the movie sounds realistic and doesn`t drown the rest of the soundtrack out. What you don`t want is the rumble of a V8 engine having the effect of a major earthquake. I think sometimes a little less is better than a little more. But as i said "It`s all down to personal taste". If it sounds right to you it is.
    :cool:
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    78dB for my set up, always sounds better a few extra dB, sounds more natural and I am not a bass nut.
  4. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    What test signal do you use as a reference. I have a DB meter and the THX optimizer on a DVD if thats any use.
