I have a Denon AVR 2105 receiver, and whilst trying out a different pair of front speakers I heard a fairly loud 'pop' shortly after the sound started when the sub kicked in. The receiver switched to protection mode and the power light started flashing. I checked the manual under 'troubleshooting' where it says 'Display not lit and power indicator is flashing rapidly' > speaker terminals are short circuited.
I checked the connections and damn I had the wires around the wrong way on the receiver. After switching them around and trying it again, it kept going back to 'protection mode' / display off..flashing power light.
In the old days it might have been a blown fuse, but there is no external fuse to check.
I then tried 'initialization of the Microprocessor (reset') with no luck.
Waited a while for it to cool down, not that it was hot or even warm to touch, and tried again no luck there either I was hoping the pop might have been the internal protection kicking in and that once the wires were reconnected correctly it would reset itself and work ..nup.
Ok ..any ideas as to what damage might have been done? .as it seems like a trip to the repairer. Does it sound like a major job as I'm wondering whether I am going to pay dearly for my blunder??
Any assistance with this would be appreciated
