What crossover settings for a sub-sat system?
Discussion in 'Home Cinema Speakers' started by cbemoore, Oct 8, 2004.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,300
    38
    Esher
    +16
    My other half is giving me grief about the size of my Mackie speakers (we've only got a small lounge) so I thought I'd try out some Kef Eggs as an experiment.
    Now everyone seems to recommend using a 120Hz crossover for the Eggs, because they don't go down that low. So before changing speakers, I decided to test my existing setup (Mackies, Servo 15 and Tag AV32R) with the crossover set to 120Hz.
    The result is - it sounds awful!! The bass now sounds really flabby, and sounds like its coming directly from the sub, whereas before it was nice and tight and non-directional.
    Is my Servo 15 just no good at these higher frequencies? Or do all sub-sat systems sound like this when you use a 120Hz crossover frequency?
    My Tag amp only allows crossover settings of 50Hz, 80Hz or 120Hz, so I'm really stuck with using 80Hz or 120Hz.
    I haven't tried connecting the Eggs yet - can they cope with an 80Hz crossover, or will this leave me with a big hole in the frequency response?
    Chris
  2. wookie
    wookie
    An 80Hz crossover is certainly OK with the EGGS.
    I would not want to go lower than this.
    I run my surround eggs x4 all at 80Hz.
    You do get a bit of the bass back due to boundary loading.
    Try them out with 80 and 120Hz settings.
    Also turn the sub level down a bit.
    HTH'S
  3. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    Take your other half on a holiday or something and stick to the Mackies!
    No really do that!
