What crossover setting do you use?
Discussion in 'AV Receivers & Amplifiers' started by FC101, Dec 17, 2003.
  1. FC101
    FC101
    Dec 16, 2003
    4
    South Africa
    I am looking at the Denon 3803 which has 40,60,80,100,120 and the Marantz 7400 which only has 80,100,120. I have B&W 603 for fronts, lcr600 for center, and 601s as rears. Sub = maybe 600 or 675. Would I need the lower crossover settings the Denon provides?
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    Aldershot, Hampshire
    +267
    I use 80Hz with my set up with fronts set to large and bass set to mains and lfe. Most people have lfe only so the mid range and higher frequencies are sent to the mains. I experimented with various settings and prefered the one I currently use.
    I'd advise you set the speaker and sub levels with an spl meter and try various combinations sticking with the one that sounds best to your ears.
    When I had my B&W 602 S3's and lrc60 I had these set to large and mains+lfe too.
  3. kev3
    kev3
    Mar 3, 2003
    73
    I've got a 3803 & AE Evo 3Bs, I've got the crossover set to 80Hz and the bass set to lfe only. Not sure if this is the best way to go, but it sounds good! any1 else?
  4. maggi
    maggi
    I´ve got Pio VSX-AX5i and have it set on 50hz.
    Speakers are:
    Front: Kef cresta 3 and have them set on large.
    Center:Kef Cresta-Small
    Rears:Kef Cresta 2-Large
    Back rears:Jamo E 4SUR-Small
    Sub:paradigm Ps-1200
    it rocks my world
    :D
    Maggi
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I find 80hz too high, speakers dont integrate well and you hear the subwoofer, so I use 60hz...
    As your front speakers are big enough, I recomend you use less than 80hz too, 60hz is the best compromise for me and several friends, even with smaller front speakers...
    My system...
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I use 80Hz on my 3802 with all speakers set to small and bass and LFE sent to subwoofer.
    Mark.
  7. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    You want to pick a crossover point that isn't being badly affected by room acoustics, 100Hz can sound great and perfectly integrated if the conditions and setup are right.
  8. inzaman
    inzaman
    Dec 16, 2002
    7,888
    Derby
    +941
    I use 100hz with my 675 & Kef eggs and it integrates very well.
  9. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    so what do you suggest for my setup??
  10. Stellavision
    Stellavision
    Apr 7, 2003
    2,286
    Southsea, UK
    +96
    Your B&W's are capable of a sub 80hz crossover, say 50hz.
    It's down to personal choice really. Have listen and see where the best fronts / sub integration is.
    Mine is set to 80hz because watching with THX on certified films the amps crossover is over ridden by the THX proccessing anyway.
    Thought I may as well stick to the same crossover while in DD and DTS mode.
