What connections for 46WM48
Discussion in 'General TV Discussions Forum' started by Riss71, Mar 15, 2005.
  1. Riss71
    Riss71
    Mar 11, 2005
    33
    Somewhere in Cardiff
    I have taken the plunge, I've just ordered the Tosh 46WM48 along with the Denon 500 (I hope Ive made the right choice eek). Could you tell me what cables I'm going to need to set this system up. I'm so confused on what connections and cables. Do I just use scarts leads or something else Help me out :lease: gents ta muchly. :)
  2. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    i believe you just need a set of components riss71 the denon 500 has components on it :thumbsup:
  3. Riss71
    Riss71
    Mar 11, 2005
    33
    Thanks Kourosh I assure you I'm not stupid, but when it comes to electrics its a case of ooh pretty pictures. Please tell me what components are ??? and where could I get some good ones?
    Cheers :)
  4. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    it all really depends how much you wanna spend qed leads are pretty good about £50 ish depending how long u want them
