What connections do you get with HD box?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by winka45, May 8, 2007.
  1. winka45
    winka45
    May 3, 2007
    1,729
    +449
    My Hd box is coming tommorow, and I was wondering what cable I get, HDMI,Component or both?
    What is the best? I have a ToshWLT32 by the way if anyone knows.
    Also if anyone has this set, what settings do you recomend, or can I just leave the settings I already use for my Sky sd.
    Cheers.
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,292
    2
    137
    Airdrie, Scotland
    +1,078
    The HD box has HDMI, Component, S-Video and RGB Scart connections. It comes with an HDMI cable.
    As for your TV, I don't know the set so can offer no advice.
    Cheers,
    Martin.
  3. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Use HDMI cable to connect your Sky HD to one of the two HDMI inputs on the 32WLT66.
  4. colham
    colham
    Mar 31, 2005
    331
    MK
    +19
    Use the HDMI cable - but note that it doesn't auto-switch (not sure thats the right term) like scart does. So you'll have to select HDMI1 or 2 depending on what you plug it into.
    I've upgraded to a gold-plated bad-boy on account of needing one for my dvd player, but the one in the box is more than adequate.
