What connection leads?
Discussion in 'Cables & Switches' started by TroyEade, Jun 3, 2005.
  1. TroyEade
    TroyEade
    I'm new member of this forum, though I have been a lurker for quite a while.
    I need to connect up my AV equipment with the best type of leads, (whilst keeping costs low):
    Toshiba 32" ZP38
    Panasonic DVD-S75
    Sony PS2
    Old Sanyo VCR (to be replaced soon)
    Panasonic Sky Digibox
    Can anyone recommend what leads I need and where to buy them from (online) please?
    Cheers,
    Troy
    PS The Tosh' set has 1 x component (guess need to use this with DVD?), 3 x SCART (of which one is S-Video).
  2. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    Sorry mate, best leads and low cost don't go together in my experience.
  3. TroyEade
    TroyEade
    TaffyBoyo,
    Thanks for the recommendations.
    Caleb,
    Appreciate comment and fully understand. What I need are leads which are matched for my system, i.e. cheap would be a waste of time, but I don't want to spend more then required to get the best out of my setup.
    All,
    Any othe recommendations?
    Thanks everyone,
    Troy
  4. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    On the basis of the best, but cheap, is a little vague (neither do you mention length) I suggest you check out TV Cables. They have quite a range of differing makes and price points, of which any will serve you well.
    As for the connections. Yes to component for the DVD, and assuming SCARTS 1 & 2 are RGB, I would use;
    Digibox - SCART 1
    PS2 - SCART 2
    VCR - SCART 3
  5. TroyEade
    TroyEade
    Thanks for your reply. I think 1 metre should be OK, as all of the kit is sat below the TV on its shelves. The spec's for the Toshiba TV inputs are:
    Input - 2 x RGB, A/V 21-pin Scart.
    Inpout/Output - 1 x A/V, S-Video, Selectable output, 21-pin Scart.
    Inpout - Y, Pb/Cb, Pr/Cr, Phono jacks.
    I haven't put quoted a budget as I don't know what is reasonable expenditure for my setup. My budget is quite flexible anyway.
    Cheers,
    Troy
