What connect should I use?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by kopite, Apr 11, 2003.
  1. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    Right I`m going listening to cd players tomorrow and now wanna know waht connectors would I be best buying
    I`ll be using a yamaha dsp630 amp for now and a sony 980 mini disc deck
    The players I`m looking at are nad 541 arcam 72t and marantz 6000
    Should I be using digital coaxial or phono?
  2. gilmore
    gilmore
    use analogue coaxial
    the dac in mentioned cd players will almost cetainly be better than the one in your amp
    if you can get cables on loan try getting one of each and wire the digital into one input on amp and the analogue into another - then just switch sources to compare the two connections
  3. gilmore
    gilmore
    the dac in mentioned cd players will be better than the one in your amp
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    sorry to p1$$ on your chips but I think you're making a mistake putting a quality CD player with your av amp. Until recently I had a 630 and combining it with a quality cd player was IMHO a waste of time, since it was frankly poor at handlind stereo music. I coupled it with a Rotel integrated amp and the quality of music shot up even from a humble pioneer 656 dvd player. Without a quality amp an Arcam 72T (VERY NICE) will be held back.
    To answer you question though, definitely go with analogue connections - the DACs in the cd player are better than the amp's.
  5. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    Yeah but I will be getting a stereo amp later
    I know its not gonna sound at its best but I aint got a cd player at the mom and think I`d be better to buy a decent one now than buy a crap one
  6. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Just to rain on your parade but ... what DVD player do you have ...
    You may find you get a bigger stereo sound improvement by spending the same on a stereo amp instead of the CD player, using the DVD player to spin discs. Or even looking at a cheeper CD player and an Amp ... a NAD C320BEE and C521i would be a similar total.
    Vikki
  7. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    Im using my pc for dvd and cd at the mom
  8. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    I`ve done things really gammily really but I bought the speakers (eltac floor standers) off a amte before I even had an amp.
    Seeing as It was only supposed to be used with my pc for games and dvds an amp didnt come into it but i`ve been bitten by the bug now so I`m going through the list to get everything.
    After I have a cd player the next will either be some decent speakers or a stereo amp
  9. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Another idea would be to get a cheeper CD player AND also a stereo amp.
    The NAD C320BEE or Rotel RA-01 with a NAD C521 would total a similar amount as the CD players you've meantioned looking at. Just another idea for you to consider - depends if you're likely to have more to spend later.
    Vikki
  10. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    Im gonna ahve laods more to spend later.
    The way I see it is Id be better off getting cd player with all the cash I have now and then get a decent amp later for about3-400 instead of buying both now and compromising.
    Thats the main reason I got a av amp with no radio in I`d rather get the best bits for the cash at the time.
    No I have a denon radio, sony mds jbc980 qs mini disc deck and my av amp after the cd player comes some new front speakers.
  11. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    What are your current speakers? You'll often find that a good amp will make speakers sound better ... but without a good amp no speaker will sound good.
    Vikki
  12. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    speakers are eltac 350 floor standers. bit naff really.
    I started out originaly with the speakers buying them off a forum and then bought the amp to use with my pc. Now I have the bug and cant stop getting new stereo stuff hehe
  13. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    How did the demo go ... what have you decided??
  14. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    It didnt go :(
    Got a phone call on friday afternoon to say they didnt have the arcam player in as they had sold the last one but I could still go along and listen to the marantz and nad :(
    GOing next weekend to a store somewhere else.
    Im starting to like the look of the arcam purely from a aesthetic view point.
  15. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    Demo happened and the arcam sounded amazing :D
    Picking it up on tuesday
  16. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    Aldershot, Hampshire
    +267
    Had my CD72t Three weeks now - it's the business. Definately get an integrated amp to go with it though. I went for the arcamA75+ in the end and i'm very happy with the results - much better than playing through my denon av amp!
  17. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,005
    Newcastle
    +277
    The Arcam will drive your B&W's better than the Denon ever could IMO. :D
  18. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    Havent got my B and w`s yet not sure If I`ll be going for them as peeps have been telling me other speakers to audition at the same time.
    ATM I`m using a yamaha amp but its amazing the difference I have noticed from the cd player as opposed to my pc
  19. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,005
    Newcastle
    +277
    So why you got them in your siggy then :p
  20. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    I aint got a siggy :p
    hehe I answered thinking u were talking to me :p
  21. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,005
    Newcastle
    +277
    LOL, I answered you thinking it was who I originally referring to :laugh:
