What colour HC room?
Discussion in 'Home Cinema Building DIY' started by davidjohnson, Aug 20, 2005.
  1. davidjohnson
    davidjohnson
    Aug 19, 2005
    2,455
    63
    +144
    I have a spare room which I intend to convert into a home cinema room.
    I will be using a projector and from what I have read so far, the ideal colour for the walls and flooring is black, to minimise reflections etc.
    Even though the room will only be used for watching films, the idea of everything being black does sound a bit naff.
    Could other members with their own rooms offer some advice please.
    Thank you.
  2. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
  3. inzaman
    inzaman
    Dec 16, 2002
    7,883
    Derby
    +935
    Check this thread out as well.
  4. davidjohnson
    davidjohnson
    Aug 19, 2005
    2,455
    63
    +144
    Thanks very much for those links.
    I appreciate the help and advice.
  5. inzaman
    inzaman
    Dec 16, 2002
    7,883
    Derby
    +935
    No problem, and welcome to the forums by the way. :)
  6. nigelbb
    nigelbb
    Apr 4, 2005
    5,262
    103
    +488
    The traditional dark red for cinemas works well too. I also have a dark blue ceiling as I thought 360 degree red might be a bit overwhelming & currently the concrete floor is just sealed with dark red concrete paint. I have some cheap dark blue carpet to match the ceiling that I need to fit.
