What Colour Goo?
Discussion in 'Projectors, Screens & Video Processors' started by GliderRider, Dec 20, 2004.
  1. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Having just agonised for month over which PJ, I've ordered the screenplay 7200.
    This will be ceiling mounted in a room that has a light colour (Natura Hessien) 4.5m X 3.5,
    I plan to paint my screen. THe web site recommends Digital Light Gray Base and Top Coat for this PJ. NEXNIX have been helpful and recommended Digital Gray(the darker colour due to the light room. This kind of makes sense?
    Anyone with a similar setup? Advice would be welome.
    Andy :lease:
  2. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    I used the dark grey base coat with the light grey top coat fot my Z2.
    If Nexnix are recommending that then it should be okay as the 7200 also has higher lumens than the Z2.
