what codecs do i need for mce 2005
Discussion in 'Microsoft Windows' started by diffinking, Mar 28, 2006.
  1. diffinking
    diffinking
    Apr 1, 2005
    198
    BELFAST
    could sumone please enlighten me on what codecs i should download for my windows media centre please
    its for hdtv
    but most codecs i need anyway
  2. SteveL
    SteveL
    May 19, 2005
    81
    Bristol, UK
    +7
  3. Rambles
    Rambles
    Jul 14, 2004
    10,314
    167
    UK
    +2,085
    And you need a dvd codec - nvidia purevideo is popular.
  4. db298
    db298
    Jun 8, 2004
    110
    +7
    It should even be possible to get by without AC3 filter if you're using later versions of FFDshow. Worth trying without first - it caused me some problems with HD material.
  5. jmbrailsford
    jmbrailsford
    May 21, 2004
    4,155
    2
    103
    Fife, Scotland
    +274
    I have just removed Theatertek and FFDshow from my machine as they were causing problems ( I think ) running dvd's and HD stuff.
    I eventually used Sonic Cineplayer DVD Decoder programme, which is only £9.99, and if you're lucky you can find a 10% off token when you go to the website.
    It is certified to run with Windows Media Player and so far so good, dvd's playing great, HDTV playing great. Maybe not as tweakable as FFDSHOW and theatretek but it's only £8.99 for the pack with the 10% off.
    I spent a week trying to get Theatertek and Media Center to play nice, but had to give up.
    Have a look at the website and see what you think.
    http://www.sonic.com/products/Consumer/CinePlayer/Decoder/quicklook.aspx
    Cheers,
    Mike.
  6. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    The problem with Sonic Cineplayer DVD Decoder is that it does not work with MCE.
  7. jmbrailsford
    jmbrailsford
    May 21, 2004
    4,155
    2
    103
    Fife, Scotland
    +274
    well it does on mine as I have removed all others that I tried, strange?
  8. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
  9. jmbrailsford
    jmbrailsford
    May 21, 2004
    4,155
    2
    103
    Fife, Scotland
    +274
    yeah was wondering about that as I previously had theatretek and nvidia installed, mind you can't check just now as computer wont work :eek:
    Cheers,
    Mike.
  10. avanzato
    avanzato
    Jan 21, 2003
    1,970
    Norfolk
    +83
    The Sonic Codec is a WMP 10 supported product and MCE is basically a pretty front end for WMP 10.
  11. DaveP
    DaveP
    Please dont take offence but I keep reading statements like this and I just wondered on what basis they were made.
    I have had several occasions when I have not been able to play something in MP10 but it plays fine in Media Center. DECCheck says the codec is fine and even running GSpot seems to indicate there is no problem but MP10 refuses to play ball. I've had to give up using MP10 altogether. No big loss though!
  12. avanzato
    avanzato
    Jan 21, 2003
    1,970
    Norfolk
    +83
    It's based on the tedious amount of effort I had to put in getting WMP 10 reconising file types so that they would then appear/play in MCE.
    I've since gone back to XP, I'm not using any 'front end' software just separate apps and my life is a lot simpler.
