What chrager for PSP?
Discussion in 'Playstation Forums' started by holden, Mar 17, 2006.
  1. holden
    holden
    Jul 25, 2005
    58
    11
    +12
    Im off to the states next week and want to take my UK PSP with me. Does anyone know if I need a particuar charger/adaptor, or will a basic plug adaptor work OK? The last thing I want is the PSP to explode on me!!
    Any suggestion or comments would be helpfull.
    cheers.
  2. gra123
    gra123
    Oct 11, 2005
    804
    Glasgow
    +86
    Just buy a normal travel adapter they are ok for europe and the usa, they cost about £5.
  3. holden
    holden
    Jul 25, 2005
    58
    11
    +12
    Thanks gra123 - much appreciated, thought I would be shelling out a small fortune.
  4. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,819
  5. holden
    holden
    Jul 25, 2005
    58
    11
    +12
    The one ive seen today at Dixons comes with a mains plug with various adaptors, but with a usb cable. I suppose this would work just as well?
  6. Repo
    Repo
    Jul 21, 2004
    430
    Sheffield, UK.
    +21
    Any universal power supply will work as long as it can output at the right voltage, wattage & polarity. I use my Dell Axim X50v charger with no problems & a universal charger although the PSP only charges when it's set to 3.5v and not 5v – the charger must be outputting too high & the PSP must have some sort of cut off protection internally.
    Look in a Beltz or other discount store when you get there - far cheaper than buying something here!
  7. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,819
    Has anyone used this USB cable/recharger from cdwow(I have a £5.00 voucher to use) http://sib1.od2.com/common/framework11.aspx?shid=0592002E I'm trying to find out if it's capable of fully recharging the PSP battery? That would be a good temp solution for me.
    CDwow also sell this one which does fully recharge the PSP battery within 3 hours but it costs a few quid more http://sib1.od2.com/common/framework11.aspx?shid=0592002E
    Any comments appreciated, really miss my PSP and want to get the bugger chrged up again:(
  8. gullarm
    gullarm
    Dec 27, 2005
    110
    +4
    The PSP power supply can connect to pretty much any power outlet world wide, all you need is the adapter to plug it in the wall.
    Check your power supply mine says 100-240v AC 50/60HZ, get a travel plug and you will be sorted.
  9. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,819
    Decided to go ahead & order this one, can't really go wrong for 99p(used my £5 voucher) with free worldwide delivery:) Now I hope they hurry up and send it, want to get my PSP powered up again, some great titles coming out for it now & I've still yet to delve into SOCOM.
  10. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    Where can I just buy a very cheap psp charger?
  11. danwalton
    danwalton
    Feb 15, 2005
    2,404
    +131
    Tetlee I was actually just about to PM you and suggest you get a USB charger for your PSP. I use one and although its quite a bit slower at charging, it works really well :thumbsup: as you say, you can't really go wrong :)
  12. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,819
    [Note, cdwow doesn't seem to allow direct links so I'll describe how to find the one I bought]
    Try looking in cdwow.co.uk, go to the games section, then the accessories, about half way down the list on the right you'll see a 'USB 2 in 1 Power Link Cable' for £5.99 delivered, don't think you'll find much cheaper than that(it's a USB charger though so as Dan mentions, it'll be alot slower).
    Hey Dan, have to meet up for another race of MarioKart DS soon, haven't managed find anyone online since the last time we played:thumbsup:
  13. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Buy a charger when you get to the US. You'll get a better deal out there.
    P.S. Like this one at Wal-Mart which has the correct US plug on it for less than £10 ($15).
