What cheap 21" TV do you recommend
Discussion in 'General TV Discussions Forum' started by Jon Weaver, Feb 2, 2003.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    Born in Bristol but now in Newport, (for my sins)
    +717
    I am replacing my 14" Portable TV in the bedroom with a cheap 21" model.
    I bought the Hitachi C2125S from Argos for £129 and it seems very good value.
    However, the Sky remote control isn't able to change the volume on this model (the volume keys operate the Teletext instead).
    I now have to try a different model.
    My main criteria are cost and more importantly 'depth' (due to space restrictions)
    Does anyone have any good or bad advice about TVs in this class?
    The other options are the Toshiba 21N21B (£140) or the Sharp 21HS50H (£189 (but £140 at Empire Direct)).
    Any advice on this would be hugely appreciated
    Jon
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    If you don't mind mono, look at the 21" Proline (Comet's Own Brand) @£99 I think it's £30 more for NICAM. Sky remote controls the TV fine. The tube is a (curved) Samsung OEM with a very respectable picture.
  3. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    +717
    Mono is fine.. I will check it out..
    Jon
