What Centre To Buy???
Discussion in 'Home Cinema Speakers' started by r4dley, Feb 11, 2009.
  1. r4dley
    r4dley
    Jan 24, 2006
    14
    Norwich
    I have a couple of mission 783s fronts and 7822 rears and wondered what centre to buy any advise would be great????
  2. mjlamoon
    mjlamoon
    Feb 18, 2005
    317
    Bramley
    +10
    I think is probally better to stick with Mission as centre to give a standard matching effect across the front
  3. r4dley
    r4dley
    Jan 24, 2006
    14
    Norwich
    But what mission should i go for i've got the 78c but dont think its up to the job?
  4. tonyrees687
    tonyrees687
    Mar 20, 2006
    2,772
    Iver Heath Bucks
    +437
    hi
    whats the budget for the centre
    it does not have to match the fronts you have (i dont think its that important with high quality speakers in a home enviroment). but the centre has to be a good one.
    befor you buy anything, ask yourself are your speakers set up to the optimum because your centre speaker is a very good one ,are so are your fronts
    i think you will have to spend a lot of money on a new centre to get noticable improvments
  5. Grayman
    Grayman
    Nov 27, 2007
    820
    +70
    If possible try and match the driver types of the 783's, mission seem to do two driver types mainly so it would be a case of seeing which suit.
